Bronco II Ford Bronco II
cold start - starving for fuel
Old Apr 6, 2004 | 01:44 PM
troyp's Avatar
troyp
Question cold start - starving for fuel
i have an 86 BII 2.9 4x4 stick plow truck. the only way to get it fired up cold is to squirt gas into the intake. it will fire up when you first hit the key, then quits and won't start. after it runs for about a minute, it will run perfect. it can sit for several hours and still start just fine. stone cold - fumbles once and then will not start. i have checked the fuel pressure - 40 pounds with the key on - even when it stalls on a cold start it never drops - about 30 lbs at idle and it will jump to 40 when goosed. i have a hunch the fuel lines may be soft and allowing air in there - is this possible? once it clears the lines, it will run absolutely perfect. i have not pulled the codes yet - it is a plow truck and there has been some "hacking" under the hood before i got it and i don't doubt it has set every code imaginable - however, it runs great besides the cold startup problem. any help would be appreciated.
tp
Old Apr 6, 2004 | 04:14 PM
mrshorty's Avatar
mrshorty
Can you hear the fuel injectors firing when it won't start?
Old Apr 7, 2004 | 07:09 AM
troyp's Avatar
troyp
that would be strange if the injectors would fire right off the bat, quit firing for a while and then start firing again. every time. and never quit firing after the first minute or 2. however, the answer is i have never tried to listen to them while cranking it over. should you be able to hear them without a stethoscope (sp)?
i figure i should jumper the fuel pumps and clear the lines and then try to fire it up cold to eliminate the "air in the lines" theory. i will do a search on this site for exactly how to jumper them and try it out tonite.
thanks
tp
Old Apr 7, 2004 | 10:36 AM
mrshorty's Avatar
mrshorty
Ford's fuel injectors are usually loud enough to hear without a stethoscope.
As for jumpering the fuel pumps, one of the leads to the self-test connector grounds the fuel pump relay.
Old Apr 7, 2004 | 03:38 PM
troyp's Avatar
troyp
anybody help with which pin to ground? i've seen the sig rtn and sto pins, but have yet to pick the fuel pump relay bypass one (only 4 other pins on that connector?)
Old Apr 8, 2004 | 08:54 AM
troyp's Avatar
troyp
let it sit for 12 hours, shorted the fuel pump relay bypass and ran the pumps to clear the lines - tried it and it started better but still fumbled and gasped for a little while. a definite improvement but not perfect. could the fuel filter be restricted and yet still show 40 lbs on the injector rail?
also, tried it this morning (about -7 celcius last nite) and it fired and stalled. cranked about 5 seconds and then stumbled to life - fumbled for a while and then started to run fine. definitely better than in the cold of winter. maybe it is just not compensating for the cold (adding enough fuel). from what i have read, the sensor that supplies the computer with the temperature for startup will normally fail such that it thinks its 50 below and run full rich and attempt to flood itself. could it fail the other way? any way to check that?
i'm thinking out loud here...
Old Apr 8, 2004 | 02:32 PM
Ken00's Avatar
Ken00
The pressure running seems a little low to me, I would expect 35psi, do you have good pressure when cranking. It is possible to have good pressure KOEO and still have low flow (volume) but you should see a decrease in pressure when the demand for fuel goes up.
Old Apr 12, 2004 | 06:52 AM
troyp's Avatar
troyp
Thumbs up the answer...
just to put this to bed, i yanked the engine cooling temp sensor and it fired right up dead cold and without so much as a fumble. infinite resistance tells the computer "very cold - full rich". problem solved. thanks to the guys who were trying to help out.
tp
Old Apr 12, 2004 | 08:03 PM
BroncII's Avatar
BroncII
That would be a code 61. Try pulling the codes again when you get a chance and see what you get.
Good luck!
ZackF350Di
Feb 15, 2017 03:49 AM
daddylee100
Feb 27, 2016 11:07 PM
Pheadrus
26
Feb 2, 2016 10:39 AM
duggyb
16
Dec 16, 2014 07:40 AM
fordmanbrad
Dec 25, 2013 10:21 PM
