Superchips Powerstroke Microtuner Now Includes OBD II Diagnostic Code Reader
Old Nov 26, 2002 | 08:05 AM
  #31
FTE Ken's Avatar
FTE Ken
Restoring it to stock leaves no codes. There is no way to tell its been programmed. Having said that, it's illegal to void the warranty because of installation of an after-market product... though some dealers seem to ignore this fact.
Old Nov 26, 2002 | 12:59 PM
  #32
79CEEJAY's Avatar
79CEEJAY
Thanks, Ken. I just wanted to make sure. I loaded the scmt today.....WOW....what a difference. It really woke up the beast!
Old Nov 26, 2002 | 01:28 PM
  #33
Mike O's Avatar
Mike O
Wow - Tuner came in todays mail - installed in less than 10 min - may have spun the tires out of my driveway....Since I plan to be towing 12000 lbs next month, I installed the tow safe settings. Any recommendations on leaving it at this or switching to Hi-Perf as long as I bring back down when towing?
Old Nov 26, 2002 | 01:39 PM
  #34
FTE Ken's Avatar
FTE Ken
There are no limits to the number of times you can switch back and forth between programs, other than physically wearing out the connector! You'll be fine running it in the high setting unloaded until then if you just want to have some fun --- just do it with safety in mind :-)
Old Nov 26, 2002 | 03:43 PM
  #35
Mike O's Avatar
Mike O
Thanks Ken, I'll switch in a couple of days after driving at 60 so I'll see the difference - Happy Bird Day.....
Old Nov 29, 2002 | 09:28 PM
  #36
haakeye50's Avatar
haakeye50
Ken I heard from a Ford dealer that they can program the 6.0 and that the after markets can do the same with ob11 I have no confermation yet but I will keep in touch. Haakeye
Old Nov 29, 2002 | 09:42 PM
  #37
FTE Ken's Avatar
FTE Ken
No, Superchips and Diablo cannot yet program them.
Old Dec 6, 2002 | 06:52 AM
  #38
79CEEJAY's Avatar
79CEEJAY
Ken, I hope this is not too far off topic...but, I want to be able to run the 80 hp setting with confidence. Soooo, I want to upgrade my exhaust. I know that the factory exhaust on my'02 is 3.5". I know that the down pipe needs to be changed, but why go to a 3.5" downpipe from the aftermarket, when stock is 3.5"? I noticed you sell a 4" downpipe and entire exhaust. Can I change JUST the downpipe, or do I need to upgrade to a larger exhaust. I know Superchip recommends upgrading the downpipe, but are really vague on the size and the rest of the exhaust. Please let me know YOUR opinion on this.
Old Dec 7, 2002 | 12:10 PM
  #39
bricot's Avatar
bricot
Ken,
Finally got my gauges installed last week, installed the offroad program to see how it did. Drove around a little seemed to be pretty good, this morning went to drive it and when you started to accelerate it was like you were putting the brakes on. Checked the lines to the boost gauge in case there was a vacuum leak all seemed good, still having the problem. Hooked up the tuner and installed the standard program and the problem seems to have gone away.
Have you heard of anything like this with the off-road program? Any thoughts?
Brian
Old Dec 8, 2002 | 02:38 PM
  #40
bbboomer's Avatar
bbboomer
I know SuperChip can reprogram "other" chips. Can they reprogram Western Diesel chips? I have an opportunity to get a Western Diesel chip but it was for an automatic rig and mine is a standard. Is this a problem? What info do they need to reprogram?
Darrell
Old Dec 8, 2002 | 04:27 PM
  #41
FTE Ken's Avatar
FTE Ken
Dealers who did that type of thing (reprogramming other brands) were doing so in violation of Superchips license agreement. They cracked down on that last February and if a dealer gets caught not only can they lose access to programs but they can be liable for damages. No, you can't use an automatic chip on a manual or visa versa. With a 1 bank module (like the Superchips) the code must match exactly or the truck won't even start.
Old Dec 9, 2002 | 12:32 PM
  #42
79CEEJAY's Avatar
79CEEJAY
Ken, when you get a chance....but is it possible for the tuner to "drop" or "forget" a portion of the programming? I returned mine to stock in order to tow heavy with it. When I returned reprogrammed it and the 1st to 2nd shifts felt a little softer than before returning to stock. When you step on it they firm up a bit, but still seem a little softer than before I reprogramed it back to stock...then back to performance. OR......am I just a little nutty.
Old Dec 9, 2002 | 01:08 PM
  #43
FTE Ken's Avatar
FTE Ken
No, its not possible. The EEPROMs are either programmed or they aren't. Plus there is a checksum calculated by the computer to make sure its programmed correctly.
Old Dec 9, 2002 | 07:48 PM
  #44
79CEEJAY's Avatar
79CEEJAY
Thanks, Ken. I guess the switching back and forth just threw off my "seat" dyno. I just wanted to ask the question though.
Old Dec 11, 2002 | 09:01 PM
  #45
vettehauler's Avatar
vettehauler
Ken (peggy actually
just got my programmer, thought I should say....
thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you, thank you,
in case you couldnt tell, Im kinda thankful.....
Drew
