Sponsored by: Real Truck
Front wheel bearings
Old Apr 2, 2004 | 06:42 PM
sd250mud's Avatar
sd250mud
I am a newbie and I need some help. I have a 2000 F250 Super Duty Crew Cab. Are the front wheel bearings serviceable? I can not get the Manual locking hubs cap off. Chiltons book is useless!! Any help or advice would be great.
I found the answer after doing a search. Sorry, should have searched more before posting
Old Apr 3, 2004 | 12:03 AM
RedTaurus94's Avatar
RedTaurus94
I did this job a couple months ago and the help I got off this website was wonderful. I also had bought a nice "Ford" service manual CD off Ebay that had some very helpful drawings. It was only a couple bucks, but it helped a lot.........
Old Apr 3, 2004 | 02:24 AM
99SuperduperV10's Avatar
99SuperduperV10
I have just replaced my front hub assemblies the lock outs have the ring clip that holds it in place after you get the clip removed I took a rubber mallet tohelp it along but the clip is all that holds it on. as for the service part you are out of luck they are sealed and can only be replaced as an assembly and not seviced and a new o-ring and bolt kit are reccomended highly. I have heard that the after market is working on a serviceable replacement but I have not seen them yet good luck hope this helps
Old Apr 3, 2004 | 09:39 AM
RedTaurus94
I should have stated that it is a pretty easy job, but pricey. One hub assembly listed for $418 at my local Ford dealer. I shopped at other places and I think NAPA said they could get one, but they didn't have it in stock. Don't remember what the price was at NAPA, but it was only a little cheaper. I finally wound up buying mine at the dealer. After a little dickering, I paid $350 and they didn't charge for the o-ring. I have worked on a couple vehicles that had serviceable bearings. Those costed little, but required a little work to install and repack the new bearings. This new-fangled set-up is easy to replace, but costs a lot more. Guess convenience is expensive.........
Old Apr 4, 2004 | 09:32 AM
tmehrkam's Avatar
tmehrkam
Auto zone has them for $299. Timken same as you get from Ford. Or so I hear.
Old Apr 4, 2004 | 09:57 AM
sd250mud's Avatar
sd250mud
Thanks for all the input. RedTaurus94, getting the manual off of ebay is excellant idea. I like to have a good manual to follow if at all possible. Great site, glad I found it.
Old Apr 5, 2004 | 10:36 AM
RedTaurus94
tmehrkam, my local AZ had no idea what I was talking about when I asked them about the hub assembly. Advanced Auto told me on the phone that they could get them, but when I got there in person, the changed their story and said the part was no longer available. Out of desperation, I stopped by the Ford dealer on my way home from AA and was able to negotiate the good price. I needed the part so I bought it. $75 off list was good enough for me, or at least as good as I thought it was going to get, if you know what I mean.........
Old Apr 5, 2004 | 01:48 PM
tmehrkam's Avatar
tmehrkam
For future reference. This is from AutoZones web site. I do not know if I have
the year model right.
The part is different depending on whether or not you have dual rear wheels and
four wheel antilock brakes.
Hope you never need it again but here it is if you do. I understand it is the exact
same part you get from FORD
Home > Shopping > Suspension & Steering > 2001 > FORD TRUCK > F250 SUPER DUTY P/U 4WD > More Info Needed
Search Results: WHEEL BEARING/HUB ASSEMBLY-FRONT
Click "Buy Online" beside the item you'd like to purchase from AutoZone.com.
Click "Add to Store List" beside the item you'd like to add to a shopping list that can be sent to and paid for at your preferred AutoZone store.
WHEEL BEARING/HUB ASSEMBLY-FRONT for a
2001 FORD TRUCK F250 SUPER DUTY P/U 4WD
WITH SINGLE REAR WHEELS (Change)
WITH 4 WHEEL ANTI-LOCK BRAKES (Change)
Normal Stock
Special Order
Not Available
Item Part
No.
Warranty Core
Value Unit
Price Availability
Store Web
TIMKEN 515020 1 YR $299.99
Old Apr 5, 2004 | 02:07 PM
Todder's Avatar
Todder
The front wheel bearings is the only problem my pops has had with his SD, he has replaced the front drivers hub 4 times. And its still not right.
Old Apr 6, 2004 | 01:28 AM
99SuperduperV10
wow markup is awful on parts I am buddies with the manager of my local NAPA and got my hub assembly for $160. the mark up on parts is more like buying jewelry for my wife I guess I expect it from the jewelry store but when you spend 30k to 50k for a truck you should be able to get a good price on parts oh well gas is to high also welcome to america land of the "free" I will buy my buddy a case of beer tomorrow just because he has saved me a fortune.
Headviking
Sep 2, 2014 06:44 PM
cochran226
Aug 19, 2010 09:09 PM
swinehart07
Escape & Escape Hybrid
May 6, 2009 06:56 AM
35w
Jul 10, 2007 01:15 AM
beatle
Nov 19, 2006 10:47 AM
