Sponsored by: Real Truck
Wheel Bearing torque
Old Nov 18, 2006 | 02:33 PM
beatle's Avatar
beatle
I am replacing the front brakes, rotors and wheel bearings on my 99 F250 SD (2 wheel drive). What is the correct torque for the front wheel bearings. Thanks for your help in advance.
Beatle
Old Nov 18, 2006 | 07:20 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Can anyone help this guy?
WELCOME to FTE!
My 2001 manual says:
Super Duty F-250, F-350 shown, Super Duty F-450, F-550 similar.
1. Remove the hub cap from the hub.
2. Remove the cotter pin and the castellated nut.
3. While rotating the wheel, tighten the adjusting nut to specification as illustrated to seat the bearings. (21ft/lbs)
4. Back off the adjusting nut until loose.
5. While rotating the wheel, tighten the adjusting nut to specification as illustrated. (18in/lbs - INCH lbs!) Torque required to rotate the hub should be 2 Nm (18 lb/in).
6. Install the castellated nut and insert a new cotter pin.
7. Install the hub cap.
Old Nov 18, 2006 | 10:16 PM
tigerman's Avatar
tigerman
My 1999 manual read identical to Krewat's
Old Nov 18, 2006 | 10:28 PM
krewat's Avatar
krewat
Thanks for backing me up !
Old Nov 19, 2006 | 10:47 AM
beatle's Avatar
beatle
Thank you both for your replies. Thats the exact information I was looking for.Beatle.
RAPTORMATT
2009 - 2014 F150
Oct 11, 2016 10:23 PM
waylen89
Aug 21, 2016 02:33 PM
TransBrain
Jul 20, 2014 05:19 PM
brucebowker
1983 - 2012 Ranger & B-Series
17
Jul 3, 2011 06:37 AM
TransplantX
Dec 30, 2009 06:55 PM
