1990 F150 Intermittent Check Engine Light
A couple of days ago I was cruising along and noticed my Check Engine light was on. The truck seemed to be running fine, but I pulled over and turned it off anyway. Checked fluids etc., everything was good, so I restarted and the light was off. I thought maybe it had just gotten "stuck" or something. A few hours later I hopped into old faithful again and the dang light was back!! So I ran it down to the auto parts store and had them run the codes. It came up with a code 41 No Exhaust Gas Oxygen switching detected-always indicating lean...and a code 67 A/C on during KOEO or nuetral drive switch open bla bla bla.. (My AC doesn't even work in the truck so it couldn't have been ON). I guess I am just being thick headed here
but can any of you tell me in plain English what my problem is with the codes of 41 and 67??? And what do I need to replace to get the silly light to go away! Thanks in advance.
My 89 460 does the 41 code if left idling for to long. Defect in the computer. I just ignore dosent hurt any thing. Never heard of this in a 1/2 ton before. EPN is right check the O2 sensor it may need replaced or cleaned. If it has been a while I would just replace any way. It would fall into the tune up catagory on an EFI.
New Problems
Thanks again for the help. I seem to have developed a new problem now, unless they are related?? Truck runs smooth when accelerating, but when I lift my foot off the peddle the darn thing will buck or jerk. Sometimes it isn't very noticable, and other times it is a very strong buck that makes a clunking sound. Can anyone give me any ideas on what this might be and how expensive it is to fix?
Again, I have a 90 F150 with a 302. Thanks again.
Tom
trucknfool - My problem was my throttle position sensor I think. It was giving me the code for that so I swapped that, but I also put on new battery cables as the old ones were cruddy as well as a new rotor - they guy I bought it from had already purchased but just hadn't put on. It was one of the three things, but I'm pretty sure it was theTPS as the code is now gone. Maybe that computer really does work sometimes.
check the codes per instructions on the www.fordfuelinjection.com site and go from there. That worked for me, anyway.
Lathan Stanley
25
09-23-2011 09:40 AM
