Wind drag, bug deflectors.
Old Mar 31, 2004 | 08:45 AM
jwirth's Avatar
jwirth
Is there any evidence to the effect that bug deflectors increase air drag thereby decreasing fuel milage? I am considering removing all unnecessary items that might reduce milage, bug deflector, luggage racks, etc.
J in VA '94 Ex
Old Mar 31, 2004 | 11:49 AM
FishX's Avatar
FishX
I haven't seen any specifics, but from a couple of different 'motoring' shows I have watched on TV, they say it does increase drag, sometimes by quite a bit.
J in VA '94 Ex
Old Mar 31, 2004 | 11:59 AM
99Xplr's Avatar
99Xplr
I have a GTS bug deflector on my 99 Explorer.... have seen less then 1/10 of a mile difference before and after.
Old Mar 31, 2004 | 02:43 PM
jwirth's Avatar
jwirth
I put mine on before I even took note of the "before" milage. I am wondering if its worth trying without.
J in VA '94 Ex
Old Apr 1, 2004 | 06:36 AM
9explorer8's Avatar
9explorer8
J,
I'm not an expert in aerodynamics by any means, but I have a feeling that at normal highway speeds bug deflectors and luggage racks are not going to influence mileage all that much. My original equipment 98 Explorer luggage rack seems pretty streamlined anyway. I also have a bug deflector on my Explorer. I find that the utility of both far out weigh any gas mileage concerns. My luggage rack has come in handy many times on trips to the hardware store to pick up lumber, pipe, etc. I installed the bug deflector after getting tired of summer driving peering out at the highway through a smear of assorted bugs. Not to mention keeping them from chipping and staining the front of the hood. The bug deflector works well and has reduced these problems a lot. Me, I'm going to keep my racks and bug deflector and not worry about the drag.
JD
Old Apr 1, 2004 | 07:53 AM
jwirth's Avatar
jwirth
JD,
You make very valid points. Yet I have never used my luggage racks and figure if I really need them, I can get them back on in a couple of minutes. I think I will wait and see what an intake kit from Ifab does for economy. I need a new air filter anyway!
Old Apr 1, 2004 | 12:10 PM
87 XLT's Avatar
87 XLT
The bug deflectors do cause some strage things to happen. At 40 MPH on my 87 Ranger the aftermarket bug deflector caused the water from my windshield washer to go toward the front of the truck, not on the windshield. I could live with that, but the way it caused my aftermarket, western style mirrors to vibrate at high speeds is why I removed the deflector.
Old Dec 2, 2004 | 07:41 AM
tomo805's Avatar
tomo805
I have a 99 explorer 4.0 SOHC with a bug deflector. I am getting 12-13 mph with mixed driving. I'm not sure this is normal and would like any input from similar situations. Wouls like to know if I should be getting more or not.
TF
Old Dec 2, 2004 | 07:52 AM
Backin72's Avatar
Backin72
I have a '94 4.0 Sport with bug deflector, luggage rack AND a sun roof deflector. I get 14 mpg city and 21 mpg highway.
tomo805, I think you may have other problems. First thing I would check is your tire pressure. I run mine at 34psi.
Old Dec 2, 2004 | 10:39 AM
jwirth's Avatar
jwirth
I have been running about 38-40 in my tires. Probably a little high. Last check, I got about 18 MPG mixed driving.
Old Dec 2, 2004 | 12:26 PM
Backin72's Avatar
Backin72
Then I would say you are getting about the average in mileage. I wouldn't worry about the bug deflector as what it's saving you in stone chips/aggravation is worth more than any increased gas mileage you MIGHT get.
Old Dec 2, 2004 | 01:23 PM
jwirth's Avatar
jwirth
True! If I could just keep those darn little bumpers in place that protect the paint.
Old Dec 2, 2004 | 01:36 PM
Backin72's Avatar
Backin72
LOL, I had the same problem. They never stayed stuck to the hood. I solved it by taking off the cheap adhesive that was on the back of them and used a small amount of auto "Goop". I also stuck them to the back of the bug shield instead of the hood. Worked like a charm!
Old Dec 2, 2004 | 04:33 PM
jwirth's Avatar
jwirth
Must try that!
jumbofordman
Jun 23, 2017 04:30 AM
Planejet42
Jul 23, 2016 10:11 AM
bo33111
Jul 3, 2016 07:02 AM
Mad Mel C
Dec 22, 2015 12:50 AM
wenger
Mar 18, 2001 04:38 PM
