Wiper Friendly Bug Deflectors
Old Mar 15, 2001 | 09:11 PM
wenger's Avatar
wenger
do they make a bug deflector or hood protector that does not aggravate the windshield wiper assembly?
thanks,
Chris
Old Mar 16, 2001 | 12:15 PM
stevieray's Avatar
stevieray
I just put the top of the line Deflecta-Shield hood protector ( with the lip on the top) on my 93 and now the wipers don't work properly and the washer won't work at all at speed. It's agood thing I got it for a song ($29.95 cdn) at a surplus store. I also got a D.S. visor too for the same price but have yet to install it. Maybe it will correct the wiper problem. SR.
Old Mar 16, 2001 | 01:01 PM
whiteboyslo's Avatar
whiteboyslo
your bug deflector affects your wiper blades? why is that? i have a "Profile" guard on mine. it's the kind tha contours to the truck and has the little lip on the top. i haven't had a problem at all with my wipers from it. (at least, no problems that were there before)
Old Mar 17, 2001 | 02:38 AM
traildawg's Avatar
traildawg
[font size="1" color="#FF0000"]LAST EDITED ON 17-Mar-01 AT 03:38 AM (EST)[/font][p]A bug shield shouldn't effect your wipers, but you will have to re-aim your washer fluid nozzles using a small pin or paper clip.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
4.9L-Auto
Pro-Comp Stage-2 6" lift
Auburn Pro-Series Diff. w/4.30:1 gears
35x12.50x15 General Grabber MT's
http://www.geocities.com/ProjectTrailDawg
Old Mar 17, 2001 | 06:14 AM
DannyP's Avatar
DannyP
Wenger, My bug shield prevents my windshield washer from working at anything over 20 mph. I guess they not only keep bugs from hitting your windshield but your washer fluid too. I have often thought of retrofitting my wipers with the setup like on my wifes Eagle Vision. It has the nozzles mounted on the wipers so it works well at any speed.
DannyP
89 F-150 4x4 former EFI I-6 now carbed 351W, Edelbrock heads,cam,intake,carb.
MSD 6A, ZF, Sterling 10.25 with 3.55L's.
Old Mar 17, 2001 | 03:44 PM
KevinT's Avatar
KevinT
If your truck is black, JCWhitney sells a wiper cowl cover that is black, covers up to the top of where the wipers sit at rest, that may help get the airflow around the wiper nozzles for you?
1995 F-150XL SC/SB
http://members.sounddomain.com/blind
5-Star Rated F-150 (Big Stereo)
Old Mar 17, 2001 | 05:53 PM
Pastmaster's Avatar
Pastmaster
I think I know what your saying, My truck will spray fluid all over the place except where I want it. I seriously doubt it would be much different even without a deflector.
Old Mar 17, 2001 | 06:08 PM
KevinT's Avatar
KevinT
I personally haven't used my windshield washer at any speed other than stopped, I tried it on the highway once but nothing sprayed out...not really too big a deal to me, I wash my truck once a week.
1995 F-150XL SC/SB
Old Mar 17, 2001 | 06:14 PM
AlM's Avatar
AlM
ford does say in my bronco's owner's manual that bug deflector's could cause this..i had an "EGR" brand that worked well..hardly any lip on top
Old Mar 17, 2001 | 08:58 PM
wenger's Avatar
wenger
it is not the problem with the fluid i am having (as i wash my truck once a week also) but my wipers pull away from the windshield, i replaced both transmissions and wiper arms (@ $40) and yet the same problem. my wipers skip, jump, make all kinds of noise. but when i take my deflector off, everything is ok. i orderd a "hood shield" (bug deflector without the upturn). my guess is this will fix the aerodynamic problem with my wipers.
Old Mar 18, 2001 | 03:15 PM
stevieray's Avatar
stevieray
The aerodynamics are being disrupted by the lip on top of the bug deflector. On my truck the rain and snow actually travel forward on the hood instead of back. If this is the case then the wind is traveling down the windshield instead of up and causes the wipers to skip and chatter. My deflectashield has the lip on it and I think I am going to cut it off to cure the problem. The other thing that I found is the rocks kicked up by other vehicles get pulled down onto the windshield instead of being blown over. Ever since I put it on the rock dings are down near the bottom of the windshield instead of up near the top. I also have a visor to install and was wondering if any one has had any problems with them. Thanks, SR.
Old Mar 18, 2001 | 04:38 PM
stevieray's Avatar
stevieray
JohnT
Mar 23, 2014 12:58 PM
LeoJr
19
Jan 24, 2012 02:36 PM
SuperSnake
23
Oct 11, 2008 07:47 PM
jwirth
13
Dec 2, 2004 04:33 PM
