Sponsored by: Real Truck
Transmission Temp Gauges
Old Apr 5, 2004 | 05:57 AM
4_jjjj's Avatar
4_jjjj
Thanks MKJRH00, that is exactly what has happened to me. The brass insert is still in the port on the drivers side. Since I was planning on changing the fluid anyway I thought I would see if it can be seen from the inside. It seems like a big coincidence that my trans starts acting up since I tightened down on this probe and broke it. Maybe it is wedged against some piece that needs to move but can not. I don't know but I'm going to open it Tuesday and see. Thanks for your insight. 4_jjjj
Old Apr 8, 2004 | 09:16 AM
fordberg's Avatar
fordberg
I bought a tranny temp gauge from Teltek. Kind of expensive but looks good and starts reading at 100 deg. I had to use a tubing cutter and insert inline with cooler.
Old Apr 9, 2004 | 06:31 AM
Longone's Avatar
Longone
Just a thought but remember the probe of the sending unit has to protrude into the oil pan ( oil flow ) to gage the temperature correctly. If the probe is recessed it will not read the actual oil temp only the temp of the oil inside the hole.
Old Apr 9, 2004 | 08:05 AM
shivelyt's Avatar
shivelyt
tranny temp gauge
I just installed one on our van. I bypassed the cooler in the radiator and connected the two hose ends into a steel T with brass nipples threaded in the T. The third hole is deep enough for the sending unit. The sending unit can be threaded in to any of the three holes to make sure of enough depth. All of this can be purchased at the local hardware. I had this same setup in a previous van for 160k miles. It works great and was easily transferred from the old vehicle to the new one. Very easy to do this way. Hope this helps.
slinginsaws
Oct 28, 2014 04:12 PM
plgebbia
Jan 20, 2009 08:55 PM
johnsjsj
Sep 18, 2007 10:07 PM
tbart16
Apr 19, 2007 03:22 PM
Lizard XJ
Mar 28, 2007 07:14 AM
