Sponsored by: Real Truck
Tranny temp gauge install
Old Mar 26, 2007 | 06:35 PM
Lizard XJ's Avatar
Lizard XJ
I tried using the search and read through several pages, and didn't find what I was looking for, I just ordered a trans temp, water temp gauge, and a full pillar pod, they are both electric, where exactly do i need to hook the sending units up to, or the best place so that I can monitor my temps with aftermarket gauges. I have an 01 V10/auto. thanks.
Old Mar 27, 2007 | 02:32 PM
Casey's Avatar
Casey
The trans sender goes in a pressure test port. It's on the driver's side of the trans, towards the front of the trans, just above the pan. There's a black hex head plug in there now. Remove the plug and install the sender. You'll only lose an ounce or so of fluid.
Old Mar 27, 2007 | 02:37 PM
bczolone's Avatar
bczolone
I recently found out that the most meaningful temps on the trans that are easiest to aquire are in the OUT line to the cooler...just tee into that...I was going to use the pressure test port also, but I have not gotten one yet...but now I might figure out how to plumb into the hose.
Old Mar 27, 2007 | 02:45 PM
fordboy2's Avatar
fordboy2
I did mine at the plug hes talking about on the side of the trans very easy.
Old Mar 27, 2007 | 06:23 PM
Lizard XJ's Avatar
Lizard XJ
thanks, I will do some looking and put the sender in their.
Old Mar 27, 2007 | 10:24 PM
hdway's Avatar
hdway
My dealers trans guy told me that the pressure port is a poor place to get the tempeture from as there is about 4" of dead oil in the passage so it takes a long time before you get any reaction on the gauge and there is no other connection to put the sensor into the slow response was my complaint. What I did was drain the oil out of the pan and drop it off Tig welded a 1/4 pipe thread half coupling on to the pan about a inch from the bottom on the drivers side and installed the sensor there, responds very well now giving me the oil temp returning from the rad to the pan.
Old Mar 28, 2007 | 07:14 AM
m350's Avatar
m350
Which cooler line is the one going to the oil cooler ?
Also anyone know the thread size so the oil cooler line can be removed from the tranny, possibly a nipple and a tee can threaded in and line attached with out cutting anything ??
breakstuff
Aug 25, 2014 01:07 PM
fixit5561
Jun 29, 2010 06:18 PM
tawd77
Feb 5, 2007 08:17 PM
dbill66
Nov 14, 2006 07:33 PM
wldcat65
Mar 8, 2006 07:21 AM
