I just got two motors one is: Block near starter D9AE-8015-f0-15, Block under intake 351 CCP-15, Heads D00E with adjustable vales (screw in studs)
The only number I found on the crank witch was not bolted too the block so it may not even go to that block are 9B2. I got one intake that fits on both blocks D90E 9425 BA, F/O 13726548. The motor mounts are also the same on both blocks.
The other is: Block near starter D4AE-6015-AA-15, Block under intake 351 WCP-15, Heads D80E AB.
Engine Identification:
351C/M/400 335 series: 8 bolts in rectangular valve covers. Timing chain housing is part of block. Thermostat housing on block. Exhaust bolt holes diagonal.
351M/400 335 series: intake is 10.7" wide the 351C is narrow.
351W/302/5.0L 6 bolts on trapezoidal valve covers. Thermostat housing on intake. Exhaust bolt holes horizontal.
429/460 385 series: 7 bolts in rectangular valve cover
352/360/390/427/428 FE series: Intake goes under valve covers.
There are other indicators but these may help.
Advustable valves means they are probably Wheezers, 351W or 302 etc,
