Ford 302 Engine Block date??
Old Oct 24, 2010 | 12:51 PM
CropDusterMan's Avatar
CropDusterMan
I have a 302 in my 66 F250, that I'm pretty sure is in the 72-73 range...
It's currently got the heads and intake off, and I'm trying to get the skinny on engine date codes...
Intake is 73, N.D got me that one...Thanks.
Bottom of stock heads says D20E
The Ex. Manifold D1AE-9431-BB
As far as the block ID goes, I was told that the stamped area in front of
#5 Cylinder was the date code...?
Mine says 3B20F
I'll be darned if I can find any info via searches.
I couldn't find anything else below the intake on the block or anything
other than the #10
Old Oct 24, 2010 | 01:02 PM
37 Ford guy's Avatar
37 Ford guy
Mine says 3B20F
other than the #10.
Hey Jason, try this.....
Locate the casting numbers on your engine block by checking above the starter on the right hand side of the block. Use a spray degreaser and a rag to clean the area if it is covered with dirt and grease.
Be aware that the casting number is a four digit alphanumeric code, followed by a dash and another four-digit number. When determining the year of your 302 cubic inch engine, only the first two characters of the first four-digit alphanumeric code are needed.
Look at the first letter in the alphanumeric code, which indicates the decade of manufacture. A "C" indicates the 1960s, "D" the 1970s, "E" the 1980s and "F" the 1990s.
Observe the second number in the four-digit alpha-numeric code. This number indicates the year of the designated decade of manufacture. For example: if your code starts with D4, your 302 engine was manufactured in 1974.
Read more: How to Identify Engine Year for a Ford 302 | eHow.com How to Identify Engine Year for a Ford 302 | eHow.com
Here's another site with some info too: http://www.classicmustang.com/casting_numbers.htm
Old Oct 24, 2010 | 02:23 PM
CropDusterMan
Thanks a bunch Randy.
Jason
Old Oct 25, 2010 | 03:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Jason & Randy, there's no need to go thru all that rigamarole.
3B20F
3B20 = February (B) 20, 1973 (3). The F is the assembly plant code.
Old Jun 18, 2014 | 03:08 PM
Scoop66's Avatar
Scoop66
Still trying to identify my 302 block
Mine says
6LT6W best i can tell (on my 302 in my 66 falcon but obviously non original)
this is behind the ignition switch on the block.
So i think maybe 6 means the year?
so 66 76 86 etc??
Then L means November?
Then T is an assembly plant somewhere or no it is the W which means assembly plant right? Is there a listing of these?
the second six is the day of the month?
can anyone provide help?
Thanks Peter
Old Jun 18, 2014 | 05:55 PM
TA455HO's Avatar
TA455HO
Lead Gopher
I'm going to suggest that it is not a 1966 dated block since the 302 did not arrive on the scene until 1968.
Old Jun 19, 2014 | 08:06 AM
Scoop66's Avatar
Scoop66
Correct not a 66 302
No i purchased this 66 Falcon with the 302 in it but he had blown the original 289 in it.
I am trying to figure out what year my 302 in my 66 is but 68 70 73 etc?
Sorry i was not clear.
Peter
trozei
40
Sep 12, 2020 09:22 PM
adam83
41
Aug 20, 2015 12:01 PM
MagickNinja
Feb 23, 2010 11:30 PM
Racemaster33
Dec 26, 2006 07:27 AM
desperado_18_2000
Sep 28, 2004 08:57 AM
