door poppers
i shaved the handles on my truck and am going to
be putting in the electric poppers. question is after installing
the hardware to unlatch the door do i need the spring loaded
pins to help open the door? if so where did you mount it and
what pound popper did you get to open the door. thanks uk
I used a Wilk-Bilt Cars remote entry kit # wlk rem-2 and a pair of Dakota Digital door poppers. I had to use the poppers to get the door to open enough so I can use my hand to open it all the way. The poppers are black and you can adjust them both by two external nuts and a internal set screw. I located the poppers on the "A" piller about 2 inches below the interior door switch. It works just fine for me.
Chuck
