1978 - 1996 Big Bronco
emissions
Old Mar 28, 2004 | 11:15 AM
ford custom's Avatar
ford custom
Question emmissions
I am haveing a problem passing my emmissions test. I have a 1990 full size Bronco with 302 in it, the worst part is I just put a rebuilt in it & it only has 1100 miles on it but my CO reading is 5 times higher than it should be. I did a cat conversion the other day. But I haven't taken it in for a test yet because it still seems to want to idle up & down but not all the time. I've replaced the O2 sencer the cat the muffler oh, by the way it had a cracked exhaust manifold & I replaced that also. I have taken it in to one mechanic but there computer would not talk to mine. The truck is running great but want pass the emmissions so if any one has any ideas they would be highly apprciated. Thanks Ford Custom, Steve
Old Mar 28, 2004 | 02:07 PM
wiggit's Avatar
wiggit
Well mine took seven times too get through, the first time with the new motor,no emmissions stuff,no cats.Find someone with a gas analizer,detune the motor too pass and then put it back too where it runs the best for you.Bring in your test sheet as a base for them too go off of and for the limits for your truck.Mine passes fine now with all the settings know for passing.
Old Mar 28, 2004 | 11:45 PM
DW2455's Avatar
DW2455
check your timming and make shure your plugs and wires are in good shape and you have a clean air filter. DW
Old Mar 29, 2004 | 11:05 AM
ford custom
Thanks DW I have it into a ford dealer now the truck seems to run great, but the idle keeps going up & down so hope they can figure this one out. I will let you all know what the prblem was. Thanks P.S. The mechanic that put the motor had the timing set at zero but another mechanic advanced it ten degrees.
Old Mar 29, 2004 | 01:47 PM
DW2455's Avatar
DW2455
well the second one was right the Base timing should be 10 BTDC. Goodluck DW
Derfus
Nov 10, 2016 12:41 PM
presidentsdad
62
Oct 23, 2015 02:25 PM
brent penfold
Exhaust Systems
Aug 12, 2015 04:46 PM
jmhatchett
6.4L Power Stroke Diesel
Jan 7, 2014 09:54 AM
picklebill
41
Jan 25, 2010 09:54 PM
