Offroad & 4x4
Married or Divorced?
Old Mar 25, 2004 | 09:58 PM
Fredman's Avatar
Fredman
Ok, i'm about ready to stick the transfer case in my truck and I ran into a few problems. I have a C-6 tranny with a married transfer case that fits an M block. I got a C-6 in my truck that is behind a 302. I also have a NP 205 divorced case sitting around.
So what is gonna be eaiser or best to do? Take the trans apart and change output shafts so the t-case will fit in my truck. Or mounting the divorced case behind the tranny thats in it now? I'm new to all this 4x4 stuff, I just dont know which transfer case would be best to use.
Old Mar 25, 2004 | 10:19 PM
proeliator's Avatar
proeliator
Stick with the married...although you didn't mention if that was a 205 as well? If its a chain drive I'd say dump it...
Old Mar 25, 2004 | 10:23 PM
Fredman's Avatar
Fredman
Both are 205s. I was just trying to get out of taking the trannys apart and swapping output shafts, but I reckon thats what i'll end up doing.
Thanks
Old Mar 25, 2004 | 10:26 PM
proeliator's Avatar
proeliator
Cool. Yea, I prefer married unless you need the divorced for the driveshaft angle. Elimates two u-joints and a driveshaft.
Old Mar 26, 2004 | 12:07 AM
ivanribic's Avatar
ivanribic
Plus it's easier on your rear driveshaft angle, although you have a little steeper angle in the front but that generally doesn't take as much abuse. If you snap a U-joint on the tranny to t-case driveline with a divorced unit you're dead in the water. At least with a married case you'll still have one axle to limp home with.
Old Mar 29, 2004 | 09:07 PM
weldingfreak's Avatar
weldingfreak
With the divorced transfercaes yoy can clock the caes around for better ground clearance
Old Mar 29, 2004 | 10:07 PM
ivanribic's Avatar
ivanribic
I don't think you can get much better clearance than having your t-case up in your frame. That's why you can see the transfer cases on highboys, divorced tend to hang lower even if you rotate them a bit. Married sit a lot higher. Bottom of my case is even with the bottom of my frame. However, a divorced will give you a better driveshaft angle if you keep it hanging down a bit lower. (Think someone already mentioned that). If you raise it you lose the only real benefit to a divorced case.
Old Mar 29, 2004 | 11:02 PM
proeliator's Avatar
proeliator
Well, like I said, I'll take a married t-case over a divorced. But, you can clock a divorced to where they have as much if not more clearance as a married, but your not increasing your driveshaft angles. Simply raising it, defeats the advantage of a divorced, like Ivan said. I did this on my '73. I'd still rather have eliminated the extra u-joints and intermediate shaft, but divorced can be set up no cost you no extra clearance. This was starting to sound a little fuzzy so I thought I'd clarify.
Old Mar 30, 2004 | 07:24 PM
weldingfreak
The other good reason for the divorced case is the ability to use two wheel drive trannys if needed. They are cheaper and more avalible
Old Mar 30, 2004 | 09:02 PM
proeliator's Avatar
proeliator
Thats a good point I never thought to mention. All you have to do is weld a bracket onto your tranny cross member and you're good to go. Thats how I was running the C-6.
ss74nova
33
Sep 12, 2014 10:12 AM
Savage Fabrication
15
Jul 8, 2013 07:21 PM
austynn2001
Apr 14, 2006 05:38 AM
hatemakings/n
Aug 18, 2005 09:55 PM
