married to divorced transfercase help
Old Jul 7, 2013 | 09:05 AM
Savage Fabrication's Avatar
Savage Fabrication
i have a 1977 ford f-250 4wd with a 460 to a c6 to a married np205 and want to swap to a divorced np205. does anyone know if it will just swap or if i need to change to a different c6 made especially for a divorced transfer case or maybe any other special parts that were different. thanks
Old Jul 7, 2013 | 09:14 AM
lasthighboy's Avatar
lasthighboy
you will need a c6 for a divorced transfer case. it will have a bolt on yoke like you transfer case mount. a 2wd trans might also work if you are going to make your own driveshaft to connect to the tcase. a 2wd uses a slip yoke out put.
Old Jul 7, 2013 | 09:16 AM
Savage Fabrication
ok thanks, my current c6 is due for a rebuild but i didn't want to do it if i was just going to have to swap it out anyway.
Old Jul 7, 2013 | 09:34 AM
lasthighboy
if ur rebuilding yours anyway you can swap the tailshaft and tailhousing to your trans and use it. either from a donor trans or (I was told) bronco graveyard has a conversion kit. (I haven't looked. and idk if it was for married or divorced from 2wd. wouldn't hurt to look tho)
Old Jul 7, 2013 | 09:53 AM
impalaslayer's Avatar
impalaslayer
why do you want to swap???
Old Jul 7, 2013 | 09:55 AM
Savage Fabrication
Gives it a more old school look and it just looks cool in my opinion.
Old Jul 7, 2013 | 10:01 AM
lasthighboy
do you have an early or late 77? highboy or lowboy?
Old Jul 7, 2013 | 10:24 AM
Savage Fabrication
Its a 1977 highboy with a 1974 body swap so there's no smog
Old Jul 7, 2013 | 10:28 AM
parkerparkerm's Avatar
parkerparkerm
If you have a highboy then you already have a divorced case.
They used 2wd transmissions with a 2footish driveshaft from the tranny to the case.
Old Jul 7, 2013 | 04:08 PM
impalaslayer
its not a high boy if it has a married case
Old Jul 7, 2013 | 04:21 PM
Savage Fabrication
It's possible it got changed. What are advantages and disadvantages?
Old Jul 7, 2013 | 04:26 PM
impalaslayer
i wouldnt swap one out for the other but thats just me. if its a HB youll have a cross member right behind the front bumper.
also if you have a maried case how, there should be a very large, wide cross member where the divorced case would have been mounted hight under the rear of the cab
Old Jul 7, 2013 | 04:28 PM
impalaslayer
Old Jul 8, 2013 | 06:43 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
REALLY.....please for your own safety do not let this thread get in the Off Road and 4x4 section, they will flame you to death for that reason.
If you have a transfer case that is actually bolted to the back of your transmission and only have 2 DS, then you probably have a 77.5 low boy and not a highboy.
Old Jul 8, 2013 | 06:49 PM
Savage Fabrication
Now that I have a few opinions and have looked into it I will leave it alone. My goal is to have a truck like the original bigfoot
