CPS Sensor
Old Mar 25, 2004 | 09:16 PM
Stroker01's Avatar
Stroker01
CPS Sensor
I have learned through this site that the CPS is the most common sensor to give any problems. At what milage range do they tend to go and what are the symptoms if any. I have 55k on mine and have developed a slight miss from time to time at idle and around 1500 rpm. Fuel filter was changed 1000mi ago.
Old Mar 25, 2004 | 09:21 PM
fourstroke's Avatar
fourstroke
Mileage seems to have no effect on the cps. When mine went bad, the engine would die at idle but would immediately restart, or, if you were cruising along it would act like you turned the key off and on real quick. It will continue to get worse until it quits completely.
johnsdiesel's Avatar
johnsdiesel
It's actually not called a CPS as most people call it, it's a CMP Sensor. It can go at any mileage. Symptoms are hesitation or stalling, eventually it won't start and the tach won't move. A bad CMP Sensor does not always throw a code either. If you have questions about part numbers or how to change it check out my contribution to the FAQ in the Super Duty forum.
Old Mar 25, 2004 | 09:22 PM
96 Canucklehead's Avatar
96 Canucklehead
I own a 96 F-250 PSD and replaced mine at approximatley 120k. Symptoms included a harsh hesitation/miss, usually while the engine was under load. I hummed and hawed about the possible cause with my mechanic for weeks until I convinced him to look at the info available on this site. Sure as ****, it was the CPS. I understand the best deal on CPSs is through an International dealer. I found that our after the installation, which could have resulted in a significant savings.
Good luck
Old Mar 25, 2004 | 09:27 PM
johnsdiesel
Not to pick (but of course I will), but can we all start calling this part by the proper name? Ford does not call it a "CPS" and neither does International.
Old Mar 25, 2004 | 09:31 PM
fourstroke's Avatar
fourstroke
I will call it a CMP, if you will tell me what the letters stand for.
Old Mar 25, 2004 | 09:32 PM
johnsdiesel
Even though Ford calls it a CMP Sensor, it stands for CaMshaft Position sensor. International calls it a CAMP Sensor.
Old Mar 25, 2004 | 09:35 PM
fourstroke's Avatar
fourstroke
Thank you, and have you considered asking Ford to call it a CPS, because it makes more sense
Old Mar 25, 2004 | 09:36 PM
Stroker01's Avatar
Stroker01
Thanks for the info Sounds like my problem is most likely the CMPsensor. Now my decision is wether to do it myself or let Ford do it under waranty.
johnsdiesel
FYI, you can get the part from International for less than $100 bucks.
Old Mar 25, 2004 | 09:41 PM
Stroker01's Avatar
Stroker01
I also have an aftermarket waranty (besides) the PSD waranty that only has a $50.00 Deductible. I got it to cover anything that the other didn't (trans, rear etc) It also covers anything the PSD does.
Old Mar 25, 2004 | 09:43 PM
johnsdiesel
Then by all means have someone change it for you. It's only 1 10mm bolt, but it's a PITA to get at it and change.
Old Mar 25, 2004 | 10:17 PM
cangim's Avatar
cangim
I agree, you already have the warranty, let some one else do it and enjoy your day.
Old Mar 25, 2004 | 11:10 PM
Stroker01's Avatar
Stroker01
Thats the way I was looking at it. I just hate dealing with the shops.
Thanks again for good info.
Leemakesmepee
28
Apr 12, 2014 09:23 PM
Patrick53
Jul 11, 2013 12:06 AM
folsomf250
13
Feb 21, 2010 04:00 PM
TimHixson
Aug 2, 2007 04:51 AM
Benny2002
Feb 26, 2007 04:23 AM
