rust spots on paint
Old Mar 25, 2004 | 10:11 AM
landstroker51's Avatar
landstroker51
rust spots on paint
I have owned two Ford products painted white. One an F-250 with Oxford white and a 2004 Explorer in Pearl white. I live in New York State and after each winter - when sping comes around I notice small rust spots or dots (very small) on the paint. Looks like it's splattered on. Would anyone know what causes this. I was told its from the brake dust and salt splashing on it??? It doesnt wash off easy and has to be taken off with a pre-wax cleaner.
Old Mar 25, 2004 | 10:25 AM
Carlene's Avatar
Carlene
Admom
Welcome to FTE.
Here's a link to a couple of discussions on the subject of Rail Dust.
https://www.ford-trucks.com/forums/s...d.php?t=217555
For the 2004, I'd take it back to the dealer and make them fix it permanently.
Good luck.
Old Mar 28, 2004 | 08:31 PM
xlrs's Avatar
xlrs
Rust spots
I have the same problem every spring. Took a full day to use pre-cleaner and my thumbnail to get them cleaned off. Salt and salt water solution is used here in Utah on the streets and freeways in winter. It almost looks as if this "BRAKEDUST" was hot when it hit the paint because it is really stuck on there.
XLRS
Old Apr 3, 2004 | 04:35 PM
GLOCK17's Avatar
GLOCK17
Just Crap In The Air Acid Rain Ect.and You Have A White Paint So It Stands Out More Start Waxing The Trucks Right Before Winter To Make It Easer To Get Off In Spring Have The Same Problem In Chicago Area.
Old Apr 6, 2004 | 10:14 PM
7DF250's Avatar
7DF250
Hey guys, what you are experiancing is called fall out. It's especially bad here in CA do not go to the dealer just go to any auto parts store and pick up some body clay or overspray clay and a bottle of quick detailer(liquid spray type) this will pull it out of the paint eaisily and leave your paint as smooth as glass making waxing effortless. hpoe this helps.
F2502011
Paint & Bodywork
Jul 28, 2012 10:11 PM
cartmanea
Oct 27, 2010 10:57 AM
cartmanea
Paint & Bodywork
Oct 26, 2010 10:03 PM
sdunham
Paint & Bodywork
Jul 29, 2003 11:29 PM
sdunham
Jul 23, 2003 12:32 PM
