Check Engine Code - Glow Plug Low Voltage
Old Mar 23, 2004 | 10:52 PM
probablecause's Avatar
probablecause
Question Check Engine Code - Glow Plug Low Voltage
Hey guys (and gals),
Alternator went out on Monday.
Blew a 30 amp engine fuse on Tuesday.
Check Engine Light came on on Tuesday.
When diagnosed with a monitor, it said low voltage to Glowplugs such-and-such on Bank 1 and 2. Anybody ever heard of this and know of a simple remedy? Truck starts and runs fine.
Thanks
Paul
Old Mar 26, 2004 | 03:55 PM
welder2000's Avatar
welder2000
My 97 did the same thing it was the glow plug relay, it still worked but was not transfering 100% of the voltig through it.Just enough to kik the code. I replaced it, problem solved.The other thing that poped up after that was the batterie light came on, took a little while to figure that one out with the help from the guys from this site. The single wire plug on the altinater had a bad conection, cleaned it, all was good. Hope this helps.
Paul Therriault
Feb 25, 2018 07:00 PM
pbruckne
6.7L Power Stroke Diesel
38
May 26, 2015 08:29 PM
paulcalif1
Modular V10 (6.8l)
Dec 26, 2013 10:34 PM
paulm
Nov 30, 2009 02:38 AM
