f-700 with cummins
Old 03-22-2004, 10:42 PM
wannaburn
wannaburn is offline
wannaburn is starting off with a positive reputation.
f-700 with cummins
I went to the local diesal performance shop today and saw in the back a f-700. I never heard of one so I went and checked it out and what I saw was a 5.9 cummins motor in it. Why is this brand new f-700 powered by a cummins
Old 03-22-2004, 10:47 PM
johnsdiesel's Avatar
johnsdiesel
johnsdiesel is offline
johnsdiesel is starting off with a positive reputation.
The only engines available above the F550 are the Power Stroke, the 5.9 Cummins, and a Cat. Personally, I would take the Cat over the Cummins or Power Stroke.
Old 03-22-2004, 10:48 PM
wannaburn
Thanks I didnt know the cummins was put in fords
Old 03-23-2004, 06:52 AM
f350xlt460's Avatar
f350xlt460
f350xlt460 is offline
f350xlt460 is starting off with a positive reputation.
i didnt think the powerstroke was available above 550. Seems to me it would be unerpowered a bit. Guess its like putting a 5.4 in a 350 c/c dually.
Old 03-23-2004, 08:50 AM
FarmerPhilCo
FarmerPhilCo is offline
FarmerPhilCo is starting off with a positive reputation.
The 444 is mild when put into the small Ford trucks. They turn the computer up when they put it into the 6-750. The only difference between the 4-550 and the 350 is the frame rails are straight and stronger and the GVRW is higher. The 6-750's are available with the 444, cummins, and the cat. The cat is the only engine that can come with the optional auto transmission (allison)
Old 03-23-2004, 11:44 AM
Casey
Casey is offline
Casey is gaining momentum as a positive member of FTE.
And the axles are larger, and the springs are larger, and the brakes are larger, and the 450/550 have 19.5" tires/wheels, etc.
Both the GVWR and GCWR are MUCH higher on the 450/550 than on the 350.
Old 03-23-2004, 02:52 PM
f350xlt460's Avatar
f350xlt460
the gcwr on a 350 is 20,000# and on a well equiped 550 its 26,000#, not much higher, but yes higher.
So, do the 6/750's with powerstoke come with a "factory power tune"? If so, is it possiable for a 350 to use a 750 computer?
Old 03-23-2004, 03:17 PM
FarmerPhilCo
it is the same computer, just configured differently.
you can tkae your truck to an international dealer and they can reconfigure your computer
Old 03-23-2004, 03:50 PM
mjwhip2
mjwhip2 is offline
mjwhip2 is starting off with a positive reputation.
What is different with the 6/750 tunes? Would it be safe to have IH recon the computer without any goodies (i.e. gauges, exhaust, etc.)?
Mike
Old 03-23-2004, 04:06 PM
FarmerPhilCo
you dont want to over do it. You can have them turn it up just a little but if you go any further you will want to beef up the drive train.
Old 03-23-2004, 06:55 PM
Casey
Casey is offline
You can get the F550 with a 30,000 pound GCWR. I have one.
Old 03-23-2004, 10:38 PM
FarmerPhilCo
you have to have a cdl to drive your 550?
odd
Old 03-24-2004, 05:46 AM
f350xlt460's Avatar
f350xlt460
in VA i think you need a CDL for anything over 26,000
Casey, ive heard of that 30,000# package, whats different then the 26,000#?
Old 03-24-2004, 07:40 AM
Casey
Casey is offline
I don't know the details about what's different. It was a selection when ordering, and since my trailer is about 22K, I got it!
And yes, I have a CDL to drive the truck and trailer.
Old 03-24-2004, 08:58 AM
FarmerPhilCo
oh, Im not doubting that you have your cdl and are capable of driving a rig, I just foud it odd that a truck that small could be set up over cdl thats all. It has to have springs and axles that are huge, my friend has a 550 roll-back and just about anything on the rear lift will make that squat.
and anything over 26,000 requires the driver to hold a cdl unless it is a registered farm use vehicle.
Quick Reply: f-700 with cummins
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
