6.7L Oil Change Info - Clarification
1st post, long time lurker, recently joined as an FTE member. I work for Ford btw and my name is Paul.
The 6.7L is more efficient from a base engine design perspective. Migrating to the CGI block material from grey iron results in much less cylinder bore distortion as well. DPF regeneration impact on oil has also been reduced significantly by using fewer "active" DPF regen cycles (post injection) in favor of "passive" regen.
The end result is far less fuel in oil dilution under most operating conditions. Extended idle and low speed stationary power applications can accelerate fuel in oil percentages over time to some extent. Truck operation at moderate highway speeds will keep this in check.
The oil life monitor/systems programming is designed such that it monitors the engines operating parameters (temp, speed, engine load, frequency of dpf regen events, etc.) and adjust oil change intervals accordingly. Some of our fleet development vehicles such as FP&L have reported >9K miles before the oil monitor activated. Note that these fleet test vehicles, along with the others we have across the country have an oil analysis performed after every oil change in most cases.
During engine development it was determined that DSI (down stream injection or 9th injector) was less desireable for a number of factors for this engine program. Refinement of the active/passive regeneration strategy, eliminating the complexity of having another low pressure fuel system to manage, improved engine efficiency and the cost were just a few of the variables.
My intent is to post from time to time when the opportunity presents itself and learn what I can to help make our products better in the future. Please know that I only frequent FTE once a week or so when workload permits and athough unfortuneately I'm unable to respond to every question or concern on the forum regarding the 6.7L or Super Duty, I will try to provide relevant information when/where I can (such as above) within the guidelines of the company. Typically I've found that hearing direct feedback from multiple owners on a particular topic/thread provides a good overview of what the good the bad and the ugly is.
Thanks for your time, have a great day!
-Paul
Disclaimer: I work at Ford, and this is my own opinion and is not the opinion of Ford Motor Company.
-Paul
The following 3 users liked this post by pbruckne:
Received 1,446 Likes
on
Thanks Paul. It's always interesting to know why certain decision were made.
I just got my 1st oil change today at 5,000 miles. Not because the message center directed me to, but because I've always thought the 1st oil change should come at earlier than normal interval. It would be wonderful if I got 8000-9000 between oil changes like you mention some of your fleet customers. I tow daily. So I consider my mile severe service.
My only compliant so far, is how fast the Michelin tires are wearing.
Paul, glad to haver you and well stated! We hope you come back occasionally and drop some more info on us. Knowledge is power and it helps us to understand these sophisticated production trucks! I've had three Ford trucks in the past. . .this new 6.7 is the only one that I've ever had an emotional attachment - it's that good!
