my 351 is overheating
Old Mar 22, 2004 | 10:52 PM
Sean351's Avatar
Sean351
I'm haveing problems with my 351 m overheating. I already put a new rad, hoses,and thermistat in it.
Old Mar 22, 2004 | 11:50 PM
mark a.'s Avatar
mark a.
What led up to this problem ? Do you have a fan schroud ?
Old Mar 23, 2004 | 12:11 AM
Sean351's Avatar
Sean351
No i dont
Old Mar 23, 2004 | 12:30 AM
Torque1st's Avatar
Torque1st
Posting Legend
You need a fan shroud in order to get the fan to work. Without a shroud the air blowing out the back of the fan just curls back around into the front of the fan. The engine will overheat unless you get going at better than 30 MPH where the motion of the vehicle starts to push air thru the radiator.
Unfortunately sometimes the engine overheats even at cruise speed if you have removed all of those little baffles. Ya know those flaps that nobody knows what they are for...
Remember Ford didn't put any of those parts on just for fun. If a part is on the vehicle there is a reason!
Make sure you have a minimum 180 t-stat. A better choice is a 190+ stat.
Old Mar 23, 2004 | 07:30 AM
dfisher1's Avatar
dfisher1
Sean,
What kind of tranny do you have?
Is it shifting OK?
Do you have an auxillary tranny cooler? The auxillary cooler are more prone to clogging and thereby burning up the tranny. This, in turn, causes the motor to overheat do to excessive heat rejection to the radiator.
An Automatic tranny can create alot of heat when in poor condition.
If this is a problem, it may overheat, as quickly as, four minutes from start up, or it could just slowly overheat over a period of an hour or more.
Do you have headers? Are the cooler lines laying across them? This is another one that people overlook.
Consider it,
KingFisher
Hmann
Sep 29, 2009 08:06 PM
fleetbob1
33
Jun 13, 2008 11:34 PM
abnjumpmaster
Jun 6, 2008 11:36 PM
cakewalker
Aug 28, 2001 01:38 AM
Katt
Jun 10, 2001 09:20 PM
