I have a 99 ranger ext-cab 4x4 4.0 and its time to replace the front brake pads. I checked the rotors and they are in very good shape, no turing needed. I was wondering has anyone tried or know how the ceramic pads are? DO they help the truck stop any better?
I just replaced my stock pads with ceramic pads. I did this because the stock pads were chewing up my rotors. Ceramic pads use ceramic compounds with copper fibers, which allow them to handle high brake temperatures with less heat fade, provide faster recovery after the stop, and generate less dust and wear on both the pads and rotors. From a comfort standpoint, they provide much quieter braking because the ceramic compounds dampen noise by producing a frequency beyond the human hearing range. They also produce little to no brake dust. Leaving your wheels looking newer longer. Best of all, they are NOT made from asbestos. As harmful as this stuff is, it is still available in brake pads. According to some studies, they meet or exceed original equipment standards. If you ask me, they are worth the extra money. I paid about $60 for a set of ceramic pads. I hope this helps.
I just replaced my front pads w/ the ceramic ones and I wouldn't never buy anything else after only having them two weeks. My '01 Ranger had about 33K on it. I went ahead and replaced the rotors anyway as it was only another $34.00. Figured the new pads would last longer. When the guy behind the counter said I wouldn't get any brake dust on my aluminum wheels, that alone sold me. Also no squeals! They seem to stop better to me as well. If I only had disks on the back now. If you have the money, I'd highly recommend it.
Jeff - Let me know what you think when you get them. Always nice to hear another opinion. I really like the performance of mine, I don't think you'll regret the decision.
Jeff,
Even though your rotors do not appear to need turning, I would have them turned to true them up and provide a good surface for the new ceramic pads to seat against. Turning is relatively inexpensive and IMHO should be doen whenever you replace the pads.
I put on the new ceramic pads and had the rotors turned and it stops a lot better then it did before. I am very happy with them so far now. Thanks for all the input.
