302 head gasket project
Old Mar 21, 2004 | 09:53 AM
Stanstruck's Avatar
Stanstruck
I have this coming up and want to plan ahead (for a change...). I'm wondering what to do while I'm there and will a Haynes manual be ok to do this with? I did an HG about a year ago with a Haynes on a 4-cylinder and replace the t-stat, water pump, timing belt while I was there.
thanks for any input,
Stan
Old Mar 22, 2004 | 02:46 PM
yellowjeep76's Avatar
yellowjeep76
The Haynes manual should be fine. There isn't much else to do in there unless you just want to change things out. I'm not sure how many miles are on your engine, but you could change out the timing chain and gears since the engine will be torn down anyway. Water pump and thermostat wouldn't be a bad idea either. You should reuse the lifters and pushrods unless they are broken. Its not a good idea to put new lifters on old camshafts. Your valve train wears the parts differently for different cam lobes and lifters/pushrods so be sure to document which came from where and put them in the same spots. The Hayes manual should cover most of this. Remember that no matter how well you think you planned almost always something will go wrong so be flexible.
Old Mar 23, 2004 | 07:26 AM
Stanstruck's Avatar
Stanstruck
Thanks yellowjeep76,
Doing the DOHC wasn't too bad, but got one of the cams a bit rotated when I put them back and had timing issues for a couple of days. Best thing was that there was only one head!
(Is it standard practice to do both heads, or common sense or??? when doing a V8?)
thanks again,
Stan
Old Mar 24, 2004 | 02:29 PM
tulsaokjoel's Avatar
tulsaokjoel
It is recommended to do both head gaskets at the same time. It won't be that much extra work, and will keep you from having to tear down the engine again if the nonreplaced one were to start leaking.
Joel
Old Mar 24, 2004 | 02:35 PM
yellowjeep76
yeah do both since you already will have most stuff out of the way anyhow. save yourself some trouble if something were to happen to the other head gasket
Old Mar 25, 2004 | 05:05 PM
scroob's Avatar
scroob
No need to pull lifters just to change head gaskets. It is VERY important to keep the pushrods in the same hole they come out of, though. Ford engines use different length pushrods to adjust the valve lash. If there are different lengths involved, you'll have a problem if you put them back wrong.
Old Mar 26, 2004 | 09:42 AM
starboy's Avatar
starboy
what about the rest?
something I'd be thinking about is good money after bad. These 302 motors run forever, so if the head gaskets are worn enough to replace, how long before the rings, valve guides, and other moving parts need replacing? If you're stripping both head and the timing cover, it's just slightly more work and budget to do the rings, oil pump, get your heads done, and change out the cam and lifters. Just a thought. Jim
brandon4
Feb 20, 2015 06:33 PM
Stanstruck
Arizona Chapter
Nov 10, 2004 02:06 AM
Stanstruck
Paint & Bodywork
Jun 28, 2004 03:48 PM
Stanstruck
15
Jul 8, 2003 11:47 AM
vettelvr
Aug 28, 2001 02:01 PM
