Bronco II Ford Bronco II
89 B II oil level sensor
Old Mar 21, 2004 | 08:46 AM
Avanti's Avatar
Avanti
The oil level sensor on my 89 BII is leaking. How do you disconnect the wire & can you just unscrew the bolt holding the sensor to remove the sensor & install new gaskets?I do not want to have to pull the pan. Apreciate the help.
Old Mar 21, 2004 | 12:20 PM
Sawfish's Avatar
Sawfish
Cool
The wire is a plug-in and pulls straight out. You do not have to pull the pan to replace the gasket (approximately $4 at your friendly Ford dealer). The factory had neglected to install one in my B-II.
This is a rather simple job, but is somewhat difficult because of the location, and lack of room to work. I used one of the fit-all swivel wrenches to remove the sensor because it was the thinnest wrench I had in that size. Worked great.
Good luck.
Old Oct 23, 2008 | 07:23 AM
WhiteBroncoII2WD's Avatar
WhiteBroncoII2WD
Good luck.
Yes, I realize this thread is a bit old, but it’s relevant to our concern: the oil level sensor. Dose the wire really just plug into the sensor or would you have to splice in a new sensor?
Old Oct 23, 2008 | 12:45 PM
WhiteBroncoII2WD
I talked with a friend today who works at Ford and he informed me that the wire that goes into the sensor is a plug and it just pulls straight out.
Kdawg89
Mar 23, 2016 03:38 PM
andrew89F250
18
Apr 6, 2012 10:29 PM
BII Plow Truck
Bronco II
Apr 17, 2009 10:12 AM
fderflinger
Aug 21, 2007 06:38 AM
Avanti
Bronco II
Jul 15, 2004 01:33 PM
