Cam Sensor Replacement
Old Mar 23, 2016 | 01:52 PM
Kdawg89's Avatar
Kdawg89
Hello,
What is the best way to change the cam sensor on these engines? I believe mine is leaking oil based on some general wetness below it and oil dripping off of the bell housing but I can't find an angle where I can see it clearly let alone replace it. Do you have to remove the power steering pump?
Old Mar 23, 2016 | 02:16 PM
Freskan6.0's Avatar
Freskan6.0
I just did mine a few weeks back, It didn't need the power steering pump removed, just the air filter because it seemed easier from the top, although it could be reached from the bottom. I think it's an 8mm bolt and I used a 1/4 inch drive with a swivel and long extension to get it. It's a little tricky to put it out because of it being long meaning the sensor. Probably the O ring is leaking if you're getting oil from it. I just put a New O ring on and it was good. I'd check wires from it for chafing mine had some. Good luck with it, shouldn't take long.
Old Mar 23, 2016 | 02:27 PM
Kdawg89's Avatar
Kdawg89
Did you just get the orings from the dealer?
Old Mar 23, 2016 | 03:38 PM
Freskan6.0's Avatar
Freskan6.0
No I have a kit that I think is from Harbor Freight or Home Depot I've had it a while. It's got a hundred or so different sizes. You should be able to find a kit at a auto parts store also. I think it's $10-15 for a kit and you'll have extras for future use.
kraigwy
Oct 26, 2013 07:54 AM
got2befast
Sep 14, 2010 11:14 PM
THE HOGG
Oct 29, 2009 10:23 AM
Matts72
General Automotive Discussion
Dec 6, 2007 12:55 AM
cowboy_transport
Feb 15, 2002 05:32 PM
