Sponsored by: Kumho
play in steering
Old Mar 20, 2004 | 08:24 PM
bob3673's Avatar
bob3673
Question play in steering
i have a 96 super cab xlt and been having trouble with play in the steering when driving truck moves form side to side a little had it aligned by two diffrent shops still not right can anyone help me
Old Mar 21, 2004 | 10:03 AM
teds74ford's Avatar
teds74ford
If it has a lot of miles, it may be the steering box. On the top there is a nut with a stud that may have an allen insert or flathead screwdriver notch. Holding the stud, loosen the nut, and then holding the nut, crank the stud clockwise a little. What you are doing is tightening the gear mesh in the box. It may help to have someone wiggle the steering wheel a little as you tighten the stud. Don't try and crank with all your might, just enough to take some of the wiggles out. The tires should twitch slightly with wheel movement. You may have to drive and readjust a couple of times to get it just right, but I think this will solve your problems. Good luck, Ted
f1002692
Dec 10, 2014 01:21 PM
kstiner
29
Nov 18, 2009 10:36 AM
menzfamfour
Aug 19, 2007 04:29 PM
wisebeard
Oct 5, 2006 08:20 AM
coolgreen
Oct 24, 2003 09:22 AM
