steering shaft play help
Old Dec 8, 2014 | 07:06 PM
f1002692's Avatar
f1002692
I have 2 to 3 inches of play in my steering column and after trying to isolate it I believe it is the part I've uploaded the picture for. What part is that? And is there anywhere else common for play in the shaft because the actually steering is pretty tight the steering wheel just moves side to side a bit without actually turning the wheels. Thanks for your help.
Old Dec 8, 2014 | 07:15 PM
Franklin2's Avatar
Franklin2
I don't see a picture yet. But if you are going to take a picture of the lower part of the column right before the steering box, that is the double d section. The double d shaft slides into the double d female part of the column. This is were the column collapses in case of a accident.
Inside this double d piece is a little leaf spring looking thing that takes the play out, but will still let it slide up in case of a accident.
Old Dec 8, 2014 | 07:22 PM
f1002692's Avatar
f1002692
http://s29.postimg.org/5td0j4yd3/20141208_114856.jpg
Sorry forgot to post it before and the play in mine seems to be up near the fire wall actually.
Old Dec 8, 2014 | 07:25 PM
Franklin2's Avatar
Franklin2
Here we go.
Old Dec 8, 2014 | 07:28 PM
f1002692's Avatar
f1002692
Sorry bout that that's where the play seems to be. Thanks for the help
Old Dec 10, 2014 | 01:21 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Left: 3 M/T / Right: A/T without tilt wheel.
3B676 is the lower steering shaft & coupler. 3A525 rag joint connects to it, then to the input shaft of the gearbox.
X-70STANG-F150
1997 - 2003 F150
Mar 26, 2016 09:01 PM
hawk1959
13
Oct 15, 2014 12:05 PM
bikeymikey
Dec 15, 2012 07:30 PM
F250racer
13
Dec 18, 2009 11:16 PM
