Temp sending unit
Old Mar 20, 2004 | 03:19 PM
tazmania18235's Avatar
tazmania18235
Temp sending unit
Can anyone tell me the location of the temp sending unit on a 1985 6.9 in a E350? I have determined the temp guage is not working properly and want to install A guage with actually temp. #'s.. Thanks for any help...
Old Mar 20, 2004 | 06:11 PM
argve's Avatar
argve
I would assume it's in the same place as on it's cousin (trucks). Look just in front of the drivers side head, just to the right of the injection pump gear housing cover, it should be on the angled piece. That is the stock sender, now for the overtemp sender (turns on at 240ish degrees) it's located right around the corner from the stock temp sender, the wiring for this shares the same loom. That sender is located on the outboard side to the head.
Old Mar 20, 2004 | 06:18 PM
tazmania18235
OK thanks for the info... I am asuming that I need to change the stock sending unit for an aftermarket gauge.. Correct???
Old Mar 20, 2004 | 06:52 PM
kitsapcountychopper's Avatar
kitsapcountychopper
correct .aftermartet should come with a sender
Old Mar 20, 2004 | 06:55 PM
tazmania18235
Thanks for the help....
I wasn't to keen on Fords till I got my Diesel....
Its my first and I know I won't go to anything else...
Old Mar 20, 2004 | 10:09 PM
argve's Avatar
argve
I have both running on The Enterprise. I left the stock sender in it's place and replaced the overtemp one with my ISSPRO sender. This way I keep the stock gauges working (for grins and giggles) but I also have a real gauge sitting in a pod on top of the dash.
Old Mar 21, 2004 | 12:13 PM
tazmania18235
Well changed it out with the stock sending unit... was unable to get to the over temp unit..... No problems.... Thanks for the help!!
kahoy
1978 - 1996 Big Bronco
Feb 6, 2024 05:02 AM
Scoop531
General Automotive Discussion
Aug 18, 2014 10:31 AM
Hiflyer746
Nov 18, 2006 01:45 PM
Flood
Apr 18, 2004 08:37 PM
mike
Jan 18, 2001 08:15 PM
