Sponsored by: Real Truck
transmission cooler
Old Sep 19, 2000 | 02:59 PM
mickssd's Avatar
mickssd
transmission cooler
Is any one aware if there is a trans and oil cooler available from ford for the V10. If there is, with what option package?
Also, has anyone put LT305/70R16 on their truck
that has 3.73 rear end. Are there any problems with this combo?
Old Sep 19, 2000 | 10:24 PM
browntrout's Avatar
browntrout
transmission cooler
Towing package is standard on all Super Duty's, I was told by a dealer that it includes the transmission cooling lines.
Old Sep 19, 2000 | 10:32 PM
supercrew's Avatar
supercrew
transmission cooler
> Is any one
>aware if there is a
>option package?
> Also, has anyone
>combo?
>I put on a set of Goodyears 305/70r16 and the only thing I noticed is that it downshifts sooner going up grades.plus the speedometer is just a tad
Old Sep 20, 2000 | 01:41 AM
V10man's Avatar
V10man
transmission cooler
If you look between the a/c condenser and the radiator you'll see a cooler approx 2' in length and 1' wide. That is the tranny cooler. The oil cooler is built into where the oil filter screws on. Two small hoses circulate coolant around the oil passage. The larger tires will zap some power with the 3.73's. Be sure to re-cal the speedo.
Old Oct 10, 2000 | 09:18 AM
crewzer's Avatar
crewzer
transmission cooler
In addition to the big oil-to-air cooler mentioned above, you should also have an oil-to-water cooler located in the bottom (cold) tank of your main radiator.
crewzer -- Y2K F250 SD 4X2 CC SB XLT 5.4LV8 AT 4.10LS TTPkg Black/Silver
Old Oct 10, 2000 | 09:35 AM
crewzer's Avatar
crewzer
transmission cooler
The LT305/70R16 tires are about 33" diameter vs 31.7" for the stock tires -- about a 4% difference.
Your speedometer and odometer will be low by this amount. The transmission shifting will be somewhat affected, and the rear-end ratio will drop to an effective 3.58.
This tire is designed for a rim width of 8-9"; the stock SD rims are 7".
Old Oct 12, 2000 | 04:42 AM
blackbeauty's Avatar
blackbeauty
transmission cooler
I've ran Goodyear Wrangler ATS's, P305/70R16, for about 30,000 miles. I run them at 32 PSI for commuting, and 45-48 PSI for towing. They ride great, look great, and I've had no problems with them. There seems to be a little increased wear in the center portion of the tire, but not enough to worry about. The downside of these tires: Goodyear does not recommend putting them on a 7" rim (I called before I bought them) and they are expensive (I paid $150 minus $88 trade-in for the stock Firestones). You are also at the mercy of the tire compnay's balancer. My truck has a 3.73LS, and it tows my 7,000 trailer very well, returning about 12 MPG using a uncorrected speedo. My lease is up in Mar00, and I will probably transfer the tires to the new truck, since I expect to receive Firestones on the new one, and my spare 305 only has about 80 miles on it. Overall, an outstanding tire.
Old Oct 12, 2000 | 10:08 AM
mickssd's Avatar
mickssd
transmission cooler
I've put over 45,000 miles on a set with my 94 Chevy 1500 4X4 and never had a problem. I also used the stock Chevy rims. I'm not sure of their rim width if 7" or 8". Did you replace your rims also?
Old Oct 13, 2000 | 04:45 AM
blackbeauty
transmission cooler
I kept the 7" rims because anything comparable (forged aluminum 3000+ lb. rating) were going to be at least $200 each. Even though Goodyear advised against it, the tire dealer said "we do it all the time". My choices at the time were between the P305 Goodyear, and a P295 BFG All-Terrain. I knew from the truck I traded in that BFG's rode hard. They also said that Goodyear took them (and other tire dealers) to their proving grounds and turned them loose in a mud pit with idenical Z71's (except for tires) and the Wrangler ATS's whipped the competition (including BFG's). Which pretty much has equalled my experience with their outstanding traction. What I'm really waiting for is some 35" Wrangler ATS's!
Old Oct 15, 2000 | 08:11 PM
captainkev's Avatar
captainkev
transmission cooler
tomthelegend
Feb 1, 2014 11:33 PM
Living Proof
Apr 30, 2013 08:07 PM
royb
2009 - 2014 F150
Aug 9, 2010 05:04 PM
Sparky83
20
May 15, 2009 06:14 AM
