any thoughts about MSD ignition
Old Mar 18, 2004 | 09:41 PM
thecowboy's Avatar
thecowboy
dose it help any? like preformance wise is it worth it? hard to install?
THANKS ALOT anything helps.
Old Mar 19, 2004 | 01:09 AM
MustangGT221's Avatar
MustangGT221
I put a 6a on my other truck that had a 6 in it and it was great (it was a 95). I have one on my 5.0 now, I'd recommend them.
Old Mar 19, 2004 | 09:02 PM
Silver Streak's Avatar
Silver Streak
I installed a 6a and TFI coil on mine a year or two ago. I didn't notice any improvement over stock. I can think of better things to do with $200. Install is a breeze, maybe 20 minutes.
Old Mar 19, 2004 | 09:34 PM
thecowboy's Avatar
thecowboy
thanks thats good to know
Old Mar 20, 2004 | 10:48 PM
optikal illushun's Avatar
optikal illushun
the stock system is perfectly fine and doesnt need to be changed unless its bad.
Old Mar 21, 2004 | 07:32 AM
low-side's Avatar
low-side
If you have a stock application, you probably won't notice much - maybe smoother idle and a little better throttle response. With some modifications that require mor revs or more fuel, it'll probably make a difference.
Old Mar 21, 2004 | 09:18 AM
ftwfred's Avatar
ftwfred
Exclamation Well worth it
Easier starts, Smoother throttle response, Smoother Idle, AND I gained about 2 MPG average over several tanks full. Installation is a breeze and with gas at $1.50 a gallon it will pay for it self in no time.....
It has worked really well for me.
ftwfred
Old Mar 21, 2004 | 03:01 PM
tetraruby300's Avatar
tetraruby300
Same as ftwfred. I've had mine for two years and have had no problems. It won't make some huge difference - especially on a stock engine, but it is notable. Shop around for the box. The adapter makes the connection a lot cleaner and easier.
Old Mar 22, 2004 | 08:03 PM
nastruk95's Avatar
nastruk95
I felt a larger difference with the tfi blaster2 coil than anything, I didn't notice anything from the box, I just put it in their to switch from my F-250 351. I wouldn't buy it except for looks, I didn't feel anything and I do a lot of towing.
Old Apr 4, 2004 | 07:45 AM
ridgerider3's Avatar
ridgerider3
Have had a 6A for a few years now, with a Mallory dist, [only aftermarket I could find!], and the only problem I had was the MSD Blaster coil went bad. [keep the old coil in the old tool box!!] They replaced it, even though it was over warranty time. After replacing Ford's "Better idea" ignition system <stupid thing would buck, snort, and basically run like moose do-do when ever it rained/mist>, I not only got better performance, I went from 15/16 mpg to 18/19 mpg. That works out to appox. $3.25 per tank @ $1.619 a gallon. OH YEA, it has payed for it self, and then some. Running a '82 F-100 300 L-6 w/stock 1bbl and exahust, SROD 4 speed <.82OD> and 2.75 rears. {She came with 232ci V-6, Tremec 3 speed, BOTH are now enjoying a new life as some other hunk of metal!}
Old Apr 5, 2004 | 02:11 PM
nastruk95's Avatar
nastruk95
what do you mean better idea ignition? Thats a big difference in fuel mileage just from an ignition change.
Old Apr 5, 2004 | 04:55 PM
Oscar Meier's Avatar
Oscar Meier
I just did the HEI / duraspark conversion to my '86 300 and I couldn't be happier. It all cost ( Including a rebuilt dizzy & Accel TFI coil) $120.00. It's well worth the bucks and it works great.
Old Apr 5, 2004 | 05:58 PM
nastruk95's Avatar
nastruk95
I know this has been asked before, but how hard was it and how did you acquire the parts?
Old Apr 6, 2004 | 05:38 AM
ridgerider3
nastruk95 what do you mean "better idea"?
YEARS ago, that was Ford's advertising slogan. I am getting to old in some regards!
The reason I replaced My ign. was for the fact that every time it rained, or even a lite mist, the trk would sputter and cut on and off. My only option was a total transplant. I aquired the box, coil, and Mallory dist from PAW in Calif. Installing was a breeze. If you know the difference between a Cresant wrench and a box/open end wrench, you can install of the parts in one afternoon. The coil requires only two wires to be modify'd, and the box has 5 <or 6 depending on your application>, two of them being the Hot and Ground. Hope this helps.
Bcjmill
Aug 20, 2017 09:54 PM
bajairon
Modular V10 (6.8l)
Dec 27, 2016 02:51 PM
Trevordickya
Dec 11, 2016 05:38 PM
petei
Aug 1, 2016 03:19 PM
EkyFordF150
15
Oct 21, 2015 02:34 PM
