Modular V10 (6.8l)
nedd help with this valve
Old Dec 22, 2016 | 11:42 PM
bajairon's Avatar
bajairon
i need help, my excursion is leaking water from this valve, i appreciate if any one can help with any info, part number? name? anything helps...
Old Dec 23, 2016 | 01:18 PM
Stewart_H's Avatar
Stewart_H
Please give us more info.
I can see it's definitely not a diesel, but I'm not familiar enough with the gassers to be able to determine if you have a 6.8L or a 5.4L engine by looking at the picture.
As well, what year is your Ex?
Stewart
Old Dec 23, 2016 | 04:34 PM
bajairon's Avatar
bajairon
hi thank you for trying to help, is a 2000 6.8L V10.
Old Dec 23, 2016 | 05:47 PM
Stewart_H's Avatar
Stewart_H
No problem.
Moved to the 6.8L V10 forum.
Stewart
Old Dec 23, 2016 | 07:31 PM
z31freakify's Avatar
z31freakify
Looks like some sort of PCV heater, I've never seen one like that before?
Old Dec 23, 2016 | 08:53 PM
Sam I Am's Avatar
Sam I Am
My 4.2L V6 has a PCV valve like that.
Old Dec 24, 2016 | 05:36 PM
Sam I Am's Avatar
Sam I Am
I have been reading about this and some vehicles got a heated PCV valve. I don't know what years had it or why some did and some didn't. There were some that used coolant to heat the PCV valve and others that used an electric heating element. The heated PCV valve was apparently used for climates that stayed very cold for long periods of time.
One post suggested that the PCV valve itself was replaceable separately from the heater assembly on the ones that used coolant to heat it. On my V6 I replaced the entire thing as an assembly.
The leak is most likely an issue with the very small heater hoses and the spring type clamps. The hoses should be replaced due to age, and if the clamps are not aging well they should be replaced also. I tend to prefer worm gear type clamps instead of the original spring type clamps. But in some tight spaces one must use what fits.
Old Dec 27, 2016 | 02:51 PM
R&T Babich's Avatar
R&T Babich
Originally Posted by Sam I Am
I have been reading about this and some vehicles got a heated PCV valve. I don't know what years had it or why some did and some didn't. There were some that used coolant to heat the PCV valve and others that used an electric heating element. The heated PCV valve was apparently used for climates that stayed very cold for long periods of time...
That is a PCV line heater.
Our 2002 Socal Ex has one, maybe it's an emissions thing in CA.
It's a 1/4" line using engine coolant for heat.
It could be bypassed with a 1/4" brass splicer fitting and I doubt it would affect anything noticeable.
Wkbrdr1
Feb 20, 2012 05:13 PM
andrewzx92000
Modular V10 (6.8l)
Nov 27, 2009 08:22 PM
Turbo F100
Modular V10 (6.8l)
Sep 22, 2008 12:42 PM
clydesride
May 25, 2006 05:58 PM
F350PSD
Nov 11, 2002 07:56 PM
