My 96 F150 has 130K, hooked to a 5 spd and 2.73 gear. I drive 120 miles interstate daily, and I read about getting more gas mileage with increased air flow. I switched to a K&N filter, and my check engine light now stays on and I've lost about 2-3 mpg. Do I need to reprogram to allow for the increased air? I already run custom exhaust through a Flowmaster, and I need my mileage back, plus some if I can manage it. Any suggestions?
I also changed plugs and wires, both by Accel at the same time, but this shouldn't have anything to do with it, should it?
Check your computer codes to see what the check engine light is for. Sometimes an over oiled K&N will make oil deposits on the filament on the MAF sensor. If the sensor is sending a bad signal to the EEC it'll throw off your air/fuel ratio. Check the codes and go from there. There isn't much for performance parts on the 6 but you can get an MSD 6a ignition and electric fans as a good start.
Every time my check engine light comes on in my 92 bronco, I disconect the battery. With the battery disconected, I touch the two cables together to zero the computer. It sucks out all the power and my check engine light stays off for a couple thousand miles.
You shouldnt be getting 2-3 mpg less with a k&n filter. Just for the heck of it, put a regular paper one in and see if your mileage comes back.
