changing fuel filter??
Old Mar 18, 2004 | 07:23 PM
yup's Avatar
yup
question about changing the fuel filter.
looking in manuals about changing a fuel filter and it says i need this tool a "Fuel Line Coupling Disconnect Tool D87L-9280-A or-B, or equivalent."
is there any other tool i could use in its place??
thanks for any help..
Old Mar 18, 2004 | 08:09 PM
kioolt's Avatar
kioolt
The tool is very cheap. I belive I paid less than $5 for mine at Pep Boys.
Old Mar 18, 2004 | 08:39 PM
MustangGT221's Avatar
MustangGT221
You can probably rent one at autozone.
Old Mar 19, 2004 | 03:50 AM
laka's Avatar
laka
What year is your truck? My '90 doesn't need the tool to remove the fuel lines from the filter. There's these little "U" shaped plastic inserts that hold the lines in place. My fuel filter comes with new clips. The lines on my pumps are also the same. Only need the tool for the fuel-rail.
Old Mar 19, 2004 | 07:37 PM
yup's Avatar
yup
i have a 1996 f150
on the drivers side underneath on the frame is the fuel filter, upon looking at it it seems that ford uses these circular springs and you have to uses either these plastic inserts or this metal scissors looking tool to slide underneath the circular spring housing. i bought this plastic set and was trying it but it would not budge as i did not want to use to much force and break them off, im going to go back and purchase the metal scissors looking tool and try that....... hopefully this works as when i tried the small round inserts it seemed i had to use alot of force to get it in there....... it has never been changed (88000 way overdue)so hopefully thats why it so hard.....
Old Mar 19, 2004 | 07:42 PM
low-side's Avatar
low-side
You should be able to get the inserts that fit into the lines at the same place that you get the tool. After they have been on that long, they probably will have taken a set and won't have any holding power anymore. I believe they're 3/8".
Old Mar 19, 2004 | 07:52 PM
yup's Avatar
yup
yeah i got the tools (the little plastic jobbies) but it deffinately still has a real good hold. i was going to mess with it more but i ran out of daylight. i got the rest of the tune-up dome though cap,rotor,plugs and wire, all i got left is just the fuel filter,pcv and this mystery part i discovered today on the back of the motor( got to consult the manual as i have no idea what it is but its broken )
brazoriastang
2004 - 2008 F150
Aug 3, 2009 06:18 AM
texas_vet
Oct 25, 2005 08:02 PM
MOOK929RR
Nov 8, 2004 05:23 PM
GasMonkey
Jul 31, 2004 06:30 PM
deltarbb
Modular V8 (4.6L, 5.4L)
Sep 5, 2001 05:13 PM
