Bronco II Ford Bronco II
power locks problem
Old Mar 18, 2004 | 07:20 PM
B2low's Avatar
B2low
power locks problem
I have an 88 B2 2wd auto tranny xlt and i am having a problem with my power locks. My unlock works but the lock doesn't. Can anyone tell me whats wrong? Thanks
Old Mar 18, 2004 | 08:06 PM
Ken00's Avatar
Ken00
I think your going to have to take the door panel off and test the circuits with a volt meter to determine were you lose power. I'm thinking its either a bad switch or accuator.
Old Mar 18, 2004 | 11:56 PM
B2low's Avatar
B2low
thanks
thanks, i'll try that and hopefully i find out whats wrong.
Old Mar 19, 2004 | 10:40 AM
Ken00's Avatar
Ken00
I have the 1989 wiring diagram if you need some help with the colors/etc.
Old Mar 19, 2004 | 04:58 PM
87 XLT's Avatar
87 XLT
One simple thing you can try is to swap the lock & unlock relays with each other. On my 87 they are on the "driver side fender apron" Probably the same on yours
Old Mar 19, 2004 | 09:10 PM
peck87's Avatar
peck87
if the actuator is the problem, try partsexpress.com. they have a universal type that you can use with minimal fabrication. by the way, i priced the one from a ford dealer. it was $149.95 each. parts express price is around $10.00. good luck!
Old Mar 22, 2004 | 01:26 PM
hazzard64's Avatar
hazzard64
i have that same problem, and i find thatif you turn the key to accessory, and hit the lock button, you cn hear a click under the hood, i also think it is in the drivers side panel. and i would like to see that wiring diagram
Old Mar 22, 2004 | 05:59 PM
GrayRanger4x4's Avatar
GrayRanger4x4
I had the same problem with my 88.It was a broke wire in the rubber elbo where the wirers go into the door.APITA to fix .Check all the fuses and make sure that all the conections are clean.While your in the door clean the window motor contors and clean and grease the windows gears.
Old Mar 22, 2004 | 06:11 PM
CrazyFazy's Avatar
CrazyFazy
My locks were sticking really bad so I sprayed WD-40 on where the lock goes up and down and they work like new. Alot of the actuators are the same off different fords its just that they need the ends changed to fit yours.
Old Mar 22, 2004 | 07:42 PM
Ken00's Avatar
Ken00
I'll try to get the wiring diagram for the power locks scanned tomorrow.
Old Mar 23, 2004 | 07:41 PM
Ken00's Avatar
Ken00
I scanned it today at work and emailed it here were I don't have a scanner, not sure how it ended up being such a large file. 1989 Power Door Locks
Vanaddiction
17
Feb 26, 2014 07:07 PM
AlaTex
Electrical Systems/Wiring
16
May 18, 2007 05:23 PM
mrmenis
Jun 1, 2004 10:39 PM
