Could headers...
Old Mar 17, 2004 | 11:36 PM
Timothy509's Avatar
Timothy509
Could headers...
Cause problems with piston rings or something?
My dad was talking to some guys that race cars
and they said that I should add an intake, carb,
exhaust, and stuff but not put headers on because
of the problems that they cause.
This is the first I've ever heard. Would I and
my 390 be okay with a set of Stan's Tri-Y
headers?
Tim
Old Mar 18, 2004 | 06:02 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Tim...
The only yime I have ever heard of something like that..Is if you had a SUPER bad leak at the hedders were they bolt up at the flange.. If cold air would get into the heads..
But if you have a leak that bad you shouldnt be driving the Vehicle anyway!!
I have run Hedders on probably 100 cars and trucks I have owned over the last 40 years.. And have not had any major trouble!!
A few small leaks here and there!! But for the most part trouble free!! Go for it!! Good luck with your tri-ys....
Even tho I have never used tri-ys..I have friends that do! and like em??
Old Mar 18, 2004 | 06:06 AM
RapidRuss's Avatar
RapidRuss
PS..Tim...
COLD air on hot pistons, rings and Valves..is not a good thing!!
Old Mar 18, 2004 | 09:45 AM
72f100's Avatar
72f100
The odds of headers causing you any of those problems is probably worse than the odds that you'll win the lotto tomorrow. Headers are a great way to increase power, gas milage, and give you a better exhaust sound.
Old Mar 18, 2004 | 09:49 AM
Scouder's Avatar
Scouder
The ONLY bad things that headers can do is leak and rust. They can, however, be difficult to install. Everything else they provide is a plus. Ask these race guys if they have headers on their race cars, I'll bet they do.
Also, the advice to spend money on intake and carb without putting on headers is questionable at best. An engine is nothing but an air pump. If you want more power, you put more air through it. If you want to draw more air in, you add bigger carb, intake, heads. But it doesn't do any good without bigger exhaust to let the air back out.
-Scouder
Old Mar 18, 2004 | 05:06 PM
Timothy509's Avatar
Timothy509
Thank you guys...Scouder the guys said that
putting headers on a race cars just not on
street machines..not too sure why they said
that. Sounded like BS to me.
Tim
Old Mar 18, 2004 | 05:10 PM
RapidRuss's Avatar
RapidRuss
Tim....
Just for your info..The truck you see in my Gallery has had the same set of hedman hedders on it for 34 years now!!
Good Luck in your Venture!! Russ!!
Old Mar 18, 2004 | 05:46 PM
cleanLX's Avatar
cleanLX
I think the 'race car guys' have a carb and intake they want to unload... .
Old Mar 18, 2004 | 08:06 PM
gtex's Avatar
gtex
Are Stan's and FPA the same guy?
I think I talked to a Stan at FPA when I got my headers.
Either way, the FPA are great headers:
http://www.thedreyerfamily.com/69f25...FPAheaders.htm
Old Mar 18, 2004 | 10:19 PM
Timothy509's Avatar
Timothy509
I'm not sure Stan's Headers is run out of
Auburn and they make headers for a lot
of different vehicles..
Tim
Old Mar 20, 2004 | 09:11 AM
Six Niner's Avatar
Six Niner
hey just wondering if you can install the FPA headers if youve got a front sway bar. (69 2wd)
Old Mar 20, 2004 | 09:27 AM
RapidRuss's Avatar
RapidRuss
I dont know about FPA's...I run hedmans on my 390 powered 70 F250 and they clear just fine!! But I bought them 34 years ago?
Good Luck!! Russ!
Old Mar 20, 2004 | 10:59 AM
padd54's Avatar
padd54
Stan's Headers are excellent!! They will build them just for your application and look awsome. Very similar to FPA's, but a little cheaper. Do a search for Stan's Headers to see their home page.
\They are going to be my headers when I get everything to rebuild my motor.
\Ray
Old Mar 20, 2004 | 02:41 PM
Six Niner's Avatar
Six Niner
Thanks Russ, i'm actually using hedman long tubes right now, so i'll give her a whirl.
appreciate the info.
abyars111
43
Oct 28, 2015 02:22 AM
abyars111
Dec 28, 2013 09:40 PM
Cudighi
Missouri Chapter
Aug 10, 2004 07:27 AM
idahocrewcab
Jan 19, 2003 12:07 AM
