ford f150 electrial
Old Mar 17, 2004 | 08:37 PM
Ron ford trucks's Avatar
Ron ford trucks
ford f150 electrial
my 1989 ford f150 died as I pulled into my driveway thinking that i ran out of gass put some in cranked nothing .checked for spark at the plug nothing checked at coil nothing tested for power to coil looked good .bad coil .replaced no spark. any sugestions ?
Old Mar 17, 2004 | 10:56 PM
Racerguy's Avatar
Racerguy
Hi Ron and welcome to the forum
One of the most common problems is a bad TFI module on the side of the distributor. It is the brains behind the ignition system.
First I would remove the distributor cap and crank the engine to check and make sure the rotor is turning. If it is then the problem is likely the TFI module or possibly the pickup coil in the distributor. There are other things that can cause it but those are the likely ones.
Old Mar 17, 2004 | 11:49 PM
PKRWUD's Avatar
PKRWUD
If you have no power to the coil when the key is on, I'd be suspicious of the ignition switch.
Redneckfordf2502002
Mar 6, 2013 11:19 PM
THAT.GUY
19
Jan 12, 2013 03:00 PM
almonyspm1
Dec 11, 2012 12:56 PM
svenska57
1997 - 2003 F150
Dec 29, 2010 08:15 PM
rednekrebel28
1997 - 2003 F150
Jul 30, 2006 08:41 AM
