Idleing too fast
Old Mar 16, 2004 | 08:28 PM
h-m's Avatar
h-m
Question Idleing too fast-Idle Air Control problem
Hi all,
I am working on my too-fast-idle problem on my 92 f150 5.0L E4OD. I have been idling about 1500 rpm for many months now and i am trying to cure it. I put in a new TPS and calabrated it like the manuel says, it didn't fix the problem. I still idle at about 1400 rpm. I looked into the Idle air control today. I am getting 11.95 vdc on the pcm side of the wire connector and 9.3 Ohms on the sensor side. This seems to be out of spec acorrding to Haynes. I expected 10.5 vdc and 11 ohms. I cleaned the valve with carb cleaner. it seemed free but i cleaned it anyway. the plunger would not come out but moved free. I am checking my Intake air temp sensor right now. hot i have 3.5K ohms, am waiting for it to cool, but seems ok right now. I had 4.6 vdc on the connector.
can you guys give me any help on what to check or change next? Is the IAC shot??? Can i do anything to it to fix it??? I unplugged it and it will idle at 1100 as soon as i start it, but after a few minutes it goes to 1400 and stays there.
thanks guys for your help.
mike
Old Mar 16, 2004 | 11:03 PM
EPNCSU2006's Avatar
EPNCSU2006
Have you tried pulling the codes? I'd also check for vacuum leaks.
Old Mar 17, 2004 | 08:30 AM
ajstephan's Avatar
ajstephan
I assume the idle screw is all the way in (sorry, have to ask). If so, then check to see if the cable is binding. However, it sounds like a serious vacuum leak to me. Have you put a vacuum guage on it? Check that, then lightly spray some carb cleaner around vacuum lines and intake ports, etc. You'll hear a change in idle speed if it hits a leak.
Old Mar 17, 2004 | 07:01 PM
h-m's Avatar
h-m
thanks much
Thanks all.
I checked for a leak earlier and didn't find anything. No change in idle. I just found the PCV valve last night, I will do a very through leak check this weekend. Do my parameters for the IAC sound ok????
hope the valve is still ok.
thanks
mike
Old Mar 18, 2004 | 12:09 AM
EPNCSU2006's Avatar
EPNCSU2006
I think the IAC valve is ok. You can unplug it, and if the truck idles normally, then you might consider replacing it.
Old Mar 18, 2004 | 02:53 AM
missouguy's Avatar
missouguy
Check your throttle position sensor. That is what was wrong with my son's F-150 5.8. Haynes manual will walk you through it using a VOM.
Frank
