Still no start.
Old Mar 6, 2013 | 06:22 PM
Redneckfordf2502002's Avatar
Redneckfordf2502002
Still no start.
Hello all I have a 1988 Ford F150 4x4 302 V8 auto transmission. I already replaced the spark plugs, wires, ignition coil, rotor, and the fuel tanks and pumps. I tried starting the truck a few days ago and nothing it cranks but no start. I had my dad check for spark and it is getting spark. Also I had my dad prime it while I was cranking it nothing still. Autozone says the distributor is bad. Could this be? the distributor I have in it I took out of a 89 F150 302 2wd not running. I would like to see this truck running soon.
Trav
Old Mar 6, 2013 | 06:36 PM
Bob Gervais's Avatar
Bob Gervais
If you've got spark the distributor should be OK.
What do you mean by priming it while cranking?
You've already checked spark, how's fuel pressure? Has this truck ever been running while you've owned it? Is the firing order of the plug wires correct?
Old Mar 6, 2013 | 06:46 PM
Redneckfordf2502002
The truck hasn't ran since I bought it about 3 years ago and so far I replaced those parts but I haven't done the external pump. I had my dad spray gasoline in the intake and I cranked the truck over but nothing happened it worked on our 89 F250. I checked the firing order already quite a few times and yes it is good. I haven't checked fuel pressure but it isn't even starting when I put gas in the intake so that seems to me to rule that out.
Trav
Old Mar 6, 2013 | 10:05 PM
42x's Avatar
42x
Put a timing light on it and see if it is 10 degress TDC. This will check the distributor and the timing chain. Mine has a plug to pull (sorry forgot the name) that needs to be removed to stop the auto advance feature.
Old Mar 6, 2013 | 10:09 PM
GNR22's Avatar
GNR22
the plug is the SPOUT connector.
If the timing isn't the issue, check compression.
Old Mar 6, 2013 | 10:29 PM
Redneckfordf2502002
so check timing and compression mainly? The timing I believe was checked and is good I can't remember for sure or not.
Trav
Old Mar 6, 2013 | 10:32 PM
GNR22's Avatar
GNR22
Recheck it. after you've checked those things, get back to us.
Old Mar 6, 2013 | 10:35 PM
Redneckfordf2502002
ok don't know when I will be able to do could be a while but will get back with y'all.
Trav
Old Mar 6, 2013 | 11:19 PM
Redneckfordf2502002
I just now rembered something that may be a help to helping me. The truck has attempted to start before just not this last time that I tried starting. When I put new plugs, wires, and coil it attempted to start but wouldn't stay running so I put new pumps in a few months later (a few days ago) and then is when it didn't attempt to start at all.
Trav
88XLTLariat
Feb 14, 2017 08:32 PM
Dyork1987
Sep 19, 2016 06:50 PM
JGuillen99
Jan 9, 2016 05:40 AM
BRay09
Feb 24, 2014 10:00 AM
BII Plow Truck
Bronco II
13
Sep 14, 2006 10:30 PM
