engine codes
Old Mar 17, 2004 | 12:52 PM
Daniel.r's Avatar
Daniel.r
engine codes
I get codes 22, 132 32 when pull the codes in my ford (1987 5.0)
22=MAP/BP sensor out of self test range
132= none
32=EVP circuit below minimum voltage of 0.24 volts
any more info would be hugely appreciated as these seem to be fairly cryptic
Daniel
Old Mar 17, 2004 | 03:45 PM
RLKBOB's Avatar
RLKBOB
Check out www.fordfuelinjection.com Lots of good info.
Old Mar 17, 2004 | 06:00 PM
yellowjeep76's Avatar
yellowjeep76
It would be safe to bet that both the MAP and EVP need to be replaced. I had the code 32 checkd the sensor and it needed replacement. Its about $50 from FORD. I tried one from Autozone but it didn't work. You may have better luck than I did, but thats just what happened to me.
Old Mar 18, 2004 | 12:13 AM
EPNCSU2006's Avatar
EPNCSU2006
I think you are counting blinks wrong. 22 is probably a 11, 11 (codes flash twice) then there is a single flash (separator pulse), then codes flash and repeat - 32, 32. MAP sensors rarely go bad. With the EGR, it could be the position sensor, or it could be a number of other things. A Haynes manual has test procedures for checking the EGR system to narrow down the problem. A code 32 can be caused by a stuck EGR valve or a bad vacuum line between the EVR and the EGR valve.
Old Mar 18, 2004 | 12:11 PM
Daniel.r's Avatar
Daniel.r
well the sweeps of my multimeter went 2 quick short pause 2 quick, longer pause 1 quick short pause 3 quick short pause 2 quick longer pause 3 quick short pause 2 quick nothing.
I did this 3 times, and get the same things each time. For the KOEO test is it the same except I start it up instead of turning the key to on? with vehicle warmed up.
Daniel
Old Mar 18, 2004 | 01:23 PM
EPNCSU2006's Avatar
EPNCSU2006
The codes are output twice for first the continuous codes, then there's a single sweep called the "separator pulse" then memory codes are output twice. KOER is the same method, but there are a couple things you might need to do. There will be an engine code (4 flashes/sweeps for a V8) then possibly a single "goose code" which when it flashes, you need to punch the gas pedal long enough for the rpms to go above 2500 rpm then let off, and turn the steering wheel at least 1/4 turn. Then the actual diagnostic codes will be output.
Old Mar 19, 2004 | 06:09 PM
Daniel.r's Avatar
Daniel.r
Wow. Thank you very much for the information, I surely do appreciate it. I have a chilton for the truck and except for a few places it is quite informative.
I'll look up the EGR check and check all the vacuum lines.
Thanks
Daniel
CoalRollinX
May 1, 2013 09:19 PM
firedaniel
Dec 26, 2011 09:31 PM
Daniel2986
1983 - 2012 Ranger & B-Series
45
Jul 14, 2006 02:47 PM
daniel_2
Sep 2, 2000 07:31 AM
daniel_2
Aug 30, 2000 08:40 PM
