extremely high idle
Old Mar 16, 2004 | 12:21 PM
guzzler96's Avatar
guzzler96
Question extremely high idle
1990 F-150 302 V-8 idling at 2200 RPM and won't kick down.
New EGR VALVE and Idle Air Control Valve.
KOEO CODE 11 - System Pass - both current code and memory code.
KOER CODE 12 - Cannot control RPM during high RPM test.
Does any of the Emmission controls affect this,i.e., TAB, TAD, EGR EVR solenoids, Air Control Valve or Bypass Valve or Smog pump if they are not working??
Has anybody out there ever had this problem?? I hope someone can help.
Old Mar 16, 2004 | 02:16 PM
yellowjeep76's Avatar
yellowjeep76
Most IACs have to be adjusted when you install a new one. You didn't mention if the problem happened right after the change or not or if you adjusted the IAC. The EGR/EVP won't really affect idle. EGR is only active under moderate load not idle or WOT. My guess is the IAC needs adjustment, if you haven't already.
Old Mar 16, 2004 | 02:51 PM
Loswald's Avatar
Loswald
try disconnecting the battery for 10 minutes then reconnecting. Start the truck and let it idle, do not give it gas for the first few minutes.
Old Mar 16, 2004 | 03:33 PM
guzzler96's Avatar
guzzler96
This all started all of a sudden. Truck was functioning fine. Made a trip to the store and the next time I restarted the truck it went straight to 2200 RPM'S. Replaced the IAC in an attempt to correct high idle problem, because of the inability to get idle to kick down.
Should there be a WOT sensor on this model, I haven't researched that, and how do you adjust the IAC??
Old Mar 16, 2004 | 11:08 PM
EPNCSU2006's Avatar
EPNCSU2006
I am unaware of any adjustment to the IAC. Check for vacuum leaks. The joint between the upper and lower intake manifolds and between the throttle body and the upper manifold are good places to start looking.
Old Mar 16, 2004 | 11:24 PM
Vermonter's Avatar
Vermonter
Sounds like an intake leak to me also, computer is adding gas to the extra air resulting in the high idle. Had the same problem with my 96 Dodge Intrepid ES, turned out it was the intake manifold gasket. Not expensive just time consuming.
Old Mar 17, 2004 | 06:44 AM
guzzler96's Avatar
guzzler96
Thanks for the feedback. If anyone else has ever encountered something like this I would like to hear. Intake leak sounds feasible. I have checked about everything else except the ECA (ECM) and don't know if that can be checked??? I am reading about PCM ( POWERTRAIN CONTROL MODULE). Does this model have both?? ECM AND PCM or just one or the other??
Old Mar 18, 2004 | 12:20 AM
EPNCSU2006's Avatar
EPNCSU2006
PCM = ECM just different terminology
Old Mar 18, 2004 | 08:58 AM
guzzler96's Avatar
guzzler96
Thanks Again. I guess the plans for this weekend are set. I appreciate everyone's help!!!
Old Mar 18, 2004 | 09:13 AM
georgesnow's Avatar
georgesnow
I had the same problem, It turned out to be a bad throttle position sensor.
Old Mar 18, 2004 | 11:25 AM
faceman1's Avatar
faceman1
i also had the same problem and it was also the tps. not that expensive and not too hard to install. laters
Old Mar 18, 2004 | 09:25 PM
AllFords1022's Avatar
AllFords1022
how do you adjust the iac valve, i had to replace one on my truck along with a tps and an o2 sensor, ran great for about two days then the idle started to climb again
Old Mar 19, 2004 | 12:17 AM
EPNCSU2006's Avatar
EPNCSU2006
There's no adjustment on the IAC.
Old Mar 19, 2004 | 02:17 PM
heathgka's Avatar
heathgka
I had the same problem for awhile. Turned out to be the ECT Sensor. Replaced it and the truck went to idleing fine.
bykr
Jun 24, 2016 10:56 AM
Jhow88
Nov 12, 2014 08:36 AM
POLARISrider500
Oct 23, 2014 11:32 AM
6Fords
Oct 4, 2014 07:02 PM
miked79928
21
Jun 8, 2014 02:43 AM
