stiff transmission when cold
Old Mar 15, 2004 | 09:57 AM
jim__r1's Avatar
jim__r1
hello all.
my manual transmission (5 speed overdrive) is a little stiff when cold, especially when shifting from first to second. it was really bad in the cold weather, I often had to double-clutch to get into 2nd gear, but it is still a little stiff (hard to throw in and sometimes get a grinding noise) even now that the weather has broken. once I drive it a bit the problem goes away. any ideas? would a change of transmission oil help? what is the recommended fluid for this transmission, and is there a friction reducer that can be used with it?
thanks in advance.
jimr
1990 F150 4.9L 5 speed manual
Old Mar 15, 2004 | 05:20 PM
steell's Avatar
steell
It's supposed to have ATF in the trans. If someone put gear oil in there, it would sure be hard to shift when it was cold.
Old Mar 15, 2004 | 05:39 PM
Talyn's Avatar
Talyn
Naw. Gear oil fine for shifting.
They just used a non synthetic, or to heavy of a weighted oil.
Old Mar 16, 2004 | 10:53 AM
jimandmandy's Avatar
jimandmandy
Try Mobil 1 ATF. Friction modifier is NOT what you want. It will cause the syncros to work even slower and lead to grinding.
Jim
Old Mar 16, 2004 | 12:34 PM
Talyn's Avatar
Talyn
he's probably got m5od.
They suck period.
I run 10w30 in mine, no problems except when its like 0 degreeze out side, thenyou can't even shift it into first that well.
Old Mar 16, 2004 | 06:54 PM
jessfactor's Avatar
jessfactor
Re: stiff transmission when cold
thats because its cold. tranny fluid is like any liquid. it flows smoother when its warmed up. it wont warm up very much ideling, but after you drive around for a while it should be a little smoother. your engine oil does the same thing, but its harder to notice and it warms up faster. i just changes my tranny fluid (M5OD) and i threw mobil 1 ATF. its 6 bucks a qt and you need 4 qts to do the job, but you dont have to do it very ofter so its better to use top of the line. it made the cold shifts a little smoother for me.
Old Mar 17, 2004 | 09:36 AM
jim__r1's Avatar
jim__r1
thanks all for the replies, very helpful. I'll take a closer look this weekend with all this new knowledge.
jr
Old Mar 17, 2004 | 10:43 AM
oldcoupe42's Avatar
oldcoupe42
Hey JR, I had a similar problem on my 96 F150 and it ended up needing a new clutch. I hope its not your problem because it was not cheap and not for the backyard mechanic
Woodtroll
Jun 10, 2007 05:14 PM
JimR1957
Oct 6, 2006 10:42 PM
JimR1957
Jul 27, 2006 09:45 PM
1988-Ranger
1983 - 2012 Ranger & B-Series
Jun 30, 2003 01:10 PM
samven
May 4, 2003 11:48 PM
