A/C Problem
Old Jul 27, 2006 | 01:42 PM
JimR1957's Avatar
JimR1957
A/C Problem
My a/c ducts will switch to defrost position when I am under somewhat heavy acceleration, as soon as I let up on the throttle they return to there normal position and will blow from the dash. I have checked the hoses under the hood and are all ok. I even replaced the little one way valve under the hood close to the firewall just in case it was not holding vacum. any ideas?
Thanks
Jim
Old Jul 27, 2006 | 02:19 PM
silvers's Avatar
silvers
Mine does the same thing! Sorry, don't have a clue why though.
Old Jul 27, 2006 | 07:49 PM
brown 4x4's Avatar
brown 4x4
Vacuum leak. It defaults to defrost if there is no vacuum present. Check vacuum lines and connections. The white one under the hood going to the a/c box is pretty common to deteriorate. The vacuum reservoir (coffee can) could also be leaking.
Old Jul 27, 2006 | 09:39 PM
JimR1957's Avatar
JimR1957
I thought it should run thru a caister of some kind but it doesn't, it only has a small one way valve. There is a vacum cannister on the fender well but the A/C is not connected to it. Where would I find a vacum diagram for it. It is a 94 f-350 with a 460?
Old Jul 27, 2006 | 09:45 PM
quicklook2's Avatar
quicklook2
go under the dash and follow it to the engine compartment.
easy to see, many fords have this problem.
JvV
Oct 23, 2011 08:44 AM
chdairy7
1997 - 2003 F150
Aug 7, 2011 07:23 AM
JIM ROLAND
60
Jun 12, 2010 09:23 AM
jostrowski
Mar 27, 2008 11:42 PM
Jim_Banville
Jul 14, 2002 05:55 PM
