e4od shifting problem, not vss, range sensor, or speedo
Old Mar 13, 2004 | 09:04 PM
n2o88's Avatar
n2o88
Ok, truck shifts like crap (nuetrals out when in overdrive if floored and won't hold in second or third without getting on and off the throttle, but not too much on it, to keep it in second or third gear). This is a 96 4x4 f150, e4od, 351w. There are no other codes than the p0755, and the code comes up without driving the truck after clearing the code out with a scanner. Code won't come on with just a key on after the clearing either. But as soon as its started and given 30 seconds or less of run time, the code shows up. This same code comes up when the plug going into the shift solenoid assembly is disconnected, along with a p0743 I guess because of the plug. I can't find any obvious wires that are bad, and would have to rip up all the sheething to look. Could it be something else? Its not the vss senser or the range sensor as both have been replaced and the abs works great, and the speedo works great.
This is getting annoying. Help me please!
Old Mar 14, 2004 | 09:06 PM
n2o88's Avatar
n2o88
t
Old Mar 17, 2004 | 06:57 PM
n2o88's Avatar
n2o88
t again
Old Mar 18, 2004 | 03:21 PM
n2o88's Avatar
n2o88
t
NM3
Jul 19, 2022 08:36 PM
Devilmanak
Feb 7, 2017 12:00 AM
jlarr
Jan 4, 2015 09:47 PM
tony. b
Jul 9, 2014 02:21 PM
TJWeikel85
Jan 17, 2014 11:08 PM
