Just looking for a little guidence installing the
new box.
Anything need to be done to assure the truck
steers correctly ,other than reinstalling the box, pitman arm to tie rod stab, lines and pump?
It's pretty straight forward. Just make sure that the bolts are in good shape. Ford says to replace after removal. Might as well put a new rag joint on while your at it. (Prolly where most of the steering slop comes from)
