Sponsored by: Innova
Question About Remote Lead
Old Mar 12, 2004 | 11:08 PM
2004lariat's Avatar
2004lariat
Ok, I have heard 2 things when running the remote power lead from you HU to your amp.
1) run it down the same side as the power line coming from your battery
or
2) run it down the same side as the RCA lines
Which is right
Thanks for your help
Old Mar 13, 2004 | 12:15 AM
acerockola77's Avatar
acerockola77
Run it down the same side as the power line comming from your battery. You always run the power and the audio lines on seperate sides.
Old Mar 15, 2004 | 03:46 PM
brianas's Avatar
brianas
to do it 100% correct -77 is right
however the remote turn on lead is a low voltage\low current lead and will not cause any problems if run along with rca cables
many rca cables even come with a built in turn on wire
g/l
Raptr241
Feb 28, 2020 12:12 PM
GORDEN1234
2009 - 2014 F150
Jan 20, 2015 10:20 AM
6.7Fan
6.7L Power Stroke Diesel
75
Aug 11, 2011 08:53 PM
fordboy_52
17
Aug 26, 2005 09:08 AM
