Sponsored by: Innova
stereo amp vs sub woofer
Old Mar 15, 2004 | 03:17 PM
feddoc's Avatar
feddoc
I have a 600W 4 channel amp that I am going to put in my truck. It will be pushing 4 polk speakers.
Is there a way to push a subwoofer off the deck amp...or do I have to get a separate amp for that???
thanks
Old Mar 15, 2004 | 03:40 PM
brianas's Avatar
brianas
some newer head units will allow you to bridge the 2 rear speaker outputs to run 1 subwoofer(2-4ohm)
but this will only give you between 50-100 watts
I would recommend a seperate power amp
g/l
Old Mar 15, 2004 | 04:32 PM
LinearPower's Avatar
LinearPower
Re: stereo amp vs sub woofer
thanks
A better idea would be to run your rear Polks off the head unit. Then run the fronts on the 2 front channels of the amp. Bridge the 2 rear channels for a 4 ohm sub.
Old Mar 15, 2004 | 05:04 PM
bill6302's Avatar
bill6302
if the amp is tri-mode stable just wire the sub to the rear channel in tri mode (wire speakers like normal but add the sub like it is bridged). i personally would just run the polks off of the head unit and run the sub with an amp
93 mix 'n match
1997 - 2003 F150
Jul 20, 2010 09:24 PM
03BLKEB
May 6, 2009 02:05 PM
bowdog
Feb 12, 2009 02:06 PM
rustynuts
Mar 6, 2006 01:29 AM
TexasX
May 28, 2004 03:43 PM
