Sponsored by: Auxito
alarm?
Old Mar 12, 2004 | 08:33 PM
F2504x4's Avatar
F2504x4
alarm?
how good is the factory alarm on these trucks, mines 97 f250 LD xlt,it shows theft on the dash and i have fob, my key looks like a stock ford key like my 95 was.
Old Mar 12, 2004 | 10:34 PM
Troll45's Avatar
Troll45
Does it have a large key? Does the theft light come on for three seconds and then go out? If it does it has a pats system. Ford doesent have an alarm system anymore that I am aware of that blows the horn when someone trys to break in or something. The Pats system just keeps the vehicle from being started with a key that is not programed for the vehicle. You can cut a regular key that will turn the ignition switch but the vehicle wont start and run. Some systems disable the starter, and others disable the fuel injectors. Roll window down, lock and close door, wait a minute, reach in through window and open door with inner door handle. If the horn starts bomping, you have an alarm system. The panic button on the key fob is for personal protection only. If someone is trying to bop you in the head while you are getting in or near your vehicle.
50belowzero
Nov 13, 2010 01:10 PM
Genesis
May 30, 2010 07:19 PM
roostonu
May 5, 2006 03:03 AM
