Over deck or between the wheel flat bed?
Old Mar 12, 2004 | 05:28 PM
04superduty's Avatar
04superduty
I plan on getting a flat bed goose neck trailer soon.( getting tired of my bumper pull) Anyway, what are the differences between a deck over and one with the deck between the wheels. I know the deck height is different and the deck will be larger on a deck over. But what other differences are there?? Any and all advice is welcome. Or experiences etc. thanks
Old Mar 12, 2004 | 09:18 PM
believer45's Avatar
believer45
As you noted, on a deck over trailer the deck is higher off the ground. They also offer a wider deck (can go up to 102" wide for the deck as opposed to 102" minus the width of both fenders). Deck overs are usually heavier built as well.
With the deck over you are far less limited in what you can drive on (my tractor will not fit on most non-deck over trailers).
It depends mostly on what you plan to do with it. The deck overs are usually a higher price due to heavier construction.
Dave / Believer45
Old Mar 13, 2004 | 08:25 AM
04superduty
Thanks for the info Dave. Anyone else have any info?
Old Mar 13, 2004 | 07:00 PM
zanec209's Avatar
zanec209
with a deck over you can load from either the side or the rear of the trailer, without the wheels wells getting in the way
Old Mar 14, 2004 | 09:31 AM
fellro86's Avatar
fellro86
As stated, it all depends upon what you are planning to use it for. The deck overs are heavier, as you can fit duals under them, but sit higher and end up with more wind drag and a bit higher center of gravity. If you aren't ever going to need the heavy weight capacity, you might consider the lower units, but if it is likely you need the extra weight ability, you will need to just get the unit you need the first time.
Old Mar 14, 2004 | 04:15 PM
04superduty
Thanks for all the input. The trailer will be used mostly for moving two 4wd vehicles around and both will have good ground clearance so I wont have to worry about problems getting on and off a triler. The other thing it will be used for is ???, you know how it goes. Everyone needs you to help them move something because you have a trailer. Most likely i will go with the deck over about 30 ft + 5 ft for the beaver tail, and 14,000 gvw. My truck is only a f 350 so anything bigger wont be of much use but there is always a what if. i want a f 550 but cant seem to find that $50,000 i set down a few months back. anyone know where i put it???
Old Mar 14, 2004 | 06:23 PM
SoCalDesertRider's Avatar
SoCalDesertRider
I put it in my pocket, but it musta fell out the hole in the bottom of it.... Hate it when that happens!
Old Mar 14, 2004 | 06:26 PM
believer45's Avatar
believer45
You might want to check into regulations for a flatbed - if you are over 10,000 on the trailer you may be required to have a CDL.
It would be kind of hard to claim the RV exemption with a flatbed.
Just another thought.
Dave / Believer45
Old Mar 14, 2004 | 09:18 PM
04superduty
I need to get a chauffeur's license for work anyway. Or i might try to get a CDL.
instyle
Mar 2, 2011 07:38 PM
jamestheron08
All Things Towing
Jun 24, 2010 11:43 AM
Blueoval_boy_64
General Diesel Discussion
Sep 9, 2009 02:21 PM
dogsniper
May 11, 2007 10:57 AM
Paso1
Jun 25, 2004 03:49 PM
