Ford vs The Competition Technical discussion and comparison ONLY. Trolls will not be tolerated.
Current ratings
Old Mar 11, 2004 | 02:39 PM
KING's Avatar
KING
Current ratings
I would appreciate accurate horsepower and torque numbers of each one of diesel engines:
CUMMINS
POWERSTROKE
DURAMAXX
Thanks.
Old Mar 11, 2004 | 03:57 PM
FordLariat's Avatar
FordLariat
Me too, and I also want ratings of those at the rear wheel, not just the flywheel.
Old Mar 11, 2004 | 07:46 PM
78fordman's Avatar
78fordman
The 6.0 is sitting at 325/560, 5.9 cummins is sitting at 325/600 i think, the HP might be off. The Durajunk is at 310/590.
Old Mar 18, 2004 | 08:59 PM
phish19's Avatar
phish19
5.4 hp 260@4500 torque 350@2500
6.8 310@4250 425@3250
6.0 325@330 560@2000
thats ford at least
Old Apr 1, 2004 | 01:47 AM
bigdieseldav's Avatar
bigdieseldav
now this is interesting...... in response to the request for rwhp ratings. I was at the Dr. performance website just looking around and they had stock dyno's for the 03 cummins(305BHP) and the 01 powerstroke (250BHP) the 03 cummins dyno'ed stock @190 rwhp while the powerstroke dyno'ed stock @ 196 rwhp.... The powerstroke gave up 55 hp at the flywheel and still put up more hp at the rear wheels? Seems odd, but based on that dyno, the Cummins will need some substantially higher flywheel ratings in order to actually outperform the Ford. That equals roughyly a 22% drivetrain loss for the ford and a 33% drivetrain loss for the dodge. If the losses hold true for the torque as well, then it is possible to assume that the 6.0 still out torques the new 600 cummins even at the 560 rating (436 to 402) Dodge has some work to do. I'm not a mechanical engineer by any means, but I personally think my theory holds a little water. Who knows?
Old Apr 1, 2004 | 02:34 AM
FordLariat's Avatar
FordLariat
That's why I wanted the rear wheel ratings, too. I knew that would be the outcome, but I had no dyno sheets to prove it. Thank you!
Old Apr 2, 2004 | 09:06 PM
P51D Mustang's Avatar
P51D Mustang
Is this with automatic or manual transmissions?
Old Apr 2, 2004 | 09:15 PM
Saurian's Avatar
Saurian
Obviously the Dodge was an Automatic transmission...and the Ford was *likely* a Manual, though it should have still pulled only a 15% loss if it was a manual.
Old Apr 2, 2004 | 09:22 PM
Ev2Demon's Avatar
Ev2Demon
Not only can manual and automatic transmissions make a difference, but 2wd or 4wd can as well. Without knowing what drivetrain each truck had, you can't make a fair comparison.
Old Apr 2, 2004 | 09:38 PM
sinister73's Avatar
sinister73
Manual transmissions are the only way to go in heavy duty work trucks. You save about a thousand dollars up front in initial cost, and you get a better transmission IMO. That dyno sheet is worthless. One of the traits which causes Dodge automatic transmission failure is all the slop that's built into them. The 47RE and 48RE transmissions (both found behind the Cummins) are made to slip their convertors alot, in order to smooth out the shift points. By all accounts, these transmissions are so sloppy that you somtimes cannot even feel them shift. This will cause huge parasitic loss to the rear wheels. With 6 speed that Cummins would be putting out at least
250 RWHP. I agree that with those numbers, the 7.3L was likely a manual transmission.
I've seen dyno charts for the Duramax diesel too, and there is a good difference in RWHP between the Allison equipt models and those with the ZF 6 speed.
I agree dave, if those results were apples to apples, the 600 Cummins would be putting less torque and HP to the rear wheels than a 6.0, but trust me- those results are not even close to being apples to apples.
Sorry Lariat...
Old Apr 3, 2004 | 12:16 AM
Ratsmoker's Avatar
Ratsmoker
I don't think the diesel autos should drain much more than the manuals. In a gas engine parasitic losses get worse at higher RPMs. Diesels only run about 3,000rpm and they have very low stall speeds. Do the new ones have lockup converters? The auto will always loose a little more than the manual but I don't think the difference is that big in the diesel world.
Old Apr 4, 2004 | 08:02 PM
emxmagnum's Avatar
emxmagnum
sorry, but the ford in question has to be an auto. the 01 strokes with autos were rated at 250 hp (just like the one in the post). the six speeds got a 275 hp rating
Old Apr 5, 2004 | 10:46 PM
FordLariat's Avatar
FordLariat
Sorry Lariat...
So those dyno sheets are irrelevant because you THINK they might not be comparable trucks? Sounds like you're quick to discredit anything Ford wins out on to me.
So, sinister73, you admit that the Cummins 600 puts less to the wheels than the 6.0? So the 6.0 has more USEABLE power than your beloved Cummins?
Old Apr 5, 2004 | 11:03 PM
sinister73's Avatar
sinister73
LOL, actually that would be jumping the gun a bit, I meant it in relative terms, but since a 6.0 / torqueshift is not the same as a 7.3 PSD, it's not really relative at all.
Also I do not necessarily believe a 6.0 would put more torque to the rear wheels than even a HO (555) Cummins. It all depends on parasitic loss due to the drivetrain, which can even vary amongst identically equipt trucks, my whole point was - no Cummins will lose that much torque/HP through a six speed manual drivetrain. It's not possible.
Also, even if a 6.0 did put more useable torque to the rear wheels than a Cummins/6 speed(6.0 would have to be a manual - or one bombed mother) that in itself would not change my mind regarding the superiority of the Cummins between these two engines.
Old Apr 5, 2004 | 11:53 PM
sinister73's Avatar
sinister73
Cummins is the number one diesel out now, and has been since 1989' (performance and reliability wise anyway).
