i've got an 88 ford F-150 and i just put in another moter out of a thunderbird and i put a cam out of a 73 351windsor in and a couple of other mods, and the computer wont work worth a damn. my mechanic told me to get a chip. where can i find a chip for it at? the motor is a 302.
Are you still running Speed density? Speed density doesn't measure the direct amount of air moving into the motor. Therefore, the computer would not know you changed the airflow characteristics over stock. You can get a custom chip burned for your application if you are not going to change the setup or mod it again. Or, you could swap to mass air flow and it will work fine as it is. Chipmaster can reprogram EEC IVs so try and contact them.
What are the cam specs? The speed density system can't cope with too much variation over stock and it sounds like you'll need a custom burn. Also, check the vacuum... if you're getting less than 13lbs you'll definitely need a custom burn.
As MustangGT221 stated, MAF can cope a lot better with cam changes.
I have no idea what the cam specs are. where can i get a chip burned at? is there a website that i can go to or what is all invovled in putting mass air flow on this pickup?
